Ga door naar hoofdinhoud
when I turn it on,i get flashing question mark.
I tried to reload os with software install disc.it starts going then computer freezes up.i then have lines lika static accross screen.i can't do anything after that but restart.i have even replaced hdd.still same.anyone seen this before
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your GPU is going
That's the lines on the screen and possible freezing... It could be "revived" for a while with a reflow, longer with a re-ball, or maybe it's time to get a new box.
The flashing ? means no boot system folder found because you didn't complete an install.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
+ agreed
door
Voeg je antwoord toe
gordongreen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,151
