Ga door naar hoofdinhoud
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
20 Vragen Bekijk alle
What is O/D off on dash board?
Why appears on the dash board a yellow light O/D off ?
Is dit een goede vraag?
Score 9
10 opmerkingen
OverDrive indicator is being ON when you press O/D button the gear shifting will use sport drive mode ( long time to shift from level to next level)
door
Thanks for the information
door
Thank u i also use the information
door
When the od show off the dash board should I disable it buy driving on high way
door
It’s confusing.. light says OD OFF.. so when light is on OD should be Off right?
door
5 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Your Over Drive has been turned off. By pressing the button on or near the shifter, you disabled Overdrive (OD). This keep the vehicle from shifting into a higher gear when you don't need it while driving around town at speeds less than 40MPH.
Was dit antwoord nuttig?
Score 12
11 opmerkingen:
I drive with overdrive on, should it be off for normal everyday driving and when should you engage it to be on or off?
door
Turn it on when on the highway at higher speeds over 40 MPH.
door
Does "OD Off" which is visible in yellow colour in hte sash board saves petrol? Which is the most economical way when driving in the city OD OFF or not
door
The over drive is basically a higher gear. So it works well at higher speeds but puts a strain on the engine at lower speeds. Think of trying to ride a bicycle in top gear at lower speeds.
door
The dash for my vehicle is showing O/D off,does this mean OD is on or off? Please help
door
6 commentaren meer tonen
Just like in a manual car, the O/D enables your car to shift in light gears when moving at a high speed. You can as well switch it off if you're moving around a place with high traffic like in a busy area, street or in town.
Score 1
The O/D Off light will turn on if you switch the overdrive function off. The O/D Off light means that your vehicle has disabled the overdrive functionality and hence your transmission cannot shift to the highest gear to facilitate acceleration on an upgrade or deceleration on a downgrade.
When the O/D Off light is on, you will be able to keep your vehicle in one gear so that you can have more manual control over your driving. This is useful in bad weather conditions when you need to be careful and precise with the maneuverability of your car.
Most automatic vehicles from Japan such as Toyota have the overdrive switch to help in switching between the usual four gears. In their cases, they won’t be able to engage the fourth gear when the overdrive is off but can be able to switch between the other three gears. You should make sure the O/D Off light is never on if you want your transmission to shift to the fourth gear to help with fuel economy.
The O/D Off light is useful when you want to help the onboard computer decide on which gear to select. This is usually the case when you are carrying a heavy load such as towing a trailer. In this case, the automatic transmission will try to shift back and forth between overdrive and the following highest gear to find a suitable speed.
Switching off the overdrive function will help your vehicle make a better decision regarding the driving speeds, engine revolutions, and gear selection. It is also favorable to let the O/D Off light stay on if you prefer engine braking when going downhill.
I found all this on this blog: O/D Off: Is it safe to drive with the light on?
Score 1
Voeg je antwoord toe
mariselaguila zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 212
Altijd: 445,118
