Ga door naar hoofdinhoud
A 3D enabled Android smartphone released in July 2011. Also known as the Thrill 4G under the AT&T network. Available in black or white, with 8 GB of internal storage, and an SD card slot expandable up to 32 GB.
I got my phone wet, HELP!
I accidentally left my phone in my pocket when I went to the beach. When I realized it, I took it apart and left it out to dry, but it still won't work. What should I do? Is it a lost cause??
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Changes are that it's a lost cause by now, but you could try to dry everything out in a tub of rice. The rice absorbs any extra moisture that might be still in the phone. Make sure you don't have any sand stuck in it as well I guess. You can use canned air to blow that stuff out.
Was dit antwoord nuttig?
1 Opmerking:
No. Just no.
door
Try to soak the logic board in at least 90 percent rubbing alcahol, i used it for a iphone 4s that went thru the washing machine and dryer but it needed a new lcd, although it connected to itunes. try a new battery also, that usually helps too.
Voeg je antwoord toe
Matthew Jones zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 194
