Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
How can I unlock it without my computer?
I just found my iphone 1st generation but i forgot my password,how can i unlock it without my computer?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
As far as I know, you will have to install iTunes on your computer and restore the firmware of the device with iTunes. It should be noted that you will lose all data on the iPhone if you use this procedure.
1. Plug your iPhone into computer with iTunes installed, and open.
2. Shut down the iPhone (hold power button and slide to power off)
3. With the iPhone off, hold the power button for three seconds
4. While holding the power button, press and hold the home button at the same time.
5. Hold both buttons for 10 seconds.
6. Let go of the power button, but continue holding the home button.
After roughly 8-10 seconds, you should see a prompt in iTunes telling you that the connected device is in recovery mode and needs to be restored. From there, follow the prompts to download the iOS firmware for your device and restore it to factory defaults.
Was dit antwoord nuttig?
Voeg je antwoord toe
ray toomata zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 371
