Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie en handleidingen voor de Apple iPhone 5c die op 10 september 2013 werd aangekondigd. Model: A1532, A1456
Icloud activation lock removal
I bought an iphone and had icloud lock on any ideas of any software to remove the icloud lock as il just have to sell this as faulty.
Thanks
Is dit een goede vraag?
Score 27
10 opmerkingen
aselachamara - Your solution only steals money from people who have already been victimized it does not work!
door Deel
@ Dan, agreed:-)
door Deel
what would be a good use for a phone in this situation? Parts?
door Deel
Logan, absolutely nothing. Only Apple can help you out. read the answer provided by "Dan"
door Deel
I'd presume at the very least you could use it for parts, everything but the logic board that is.
door Deel
5 commentaren meer tonen
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Gekozen oplossing
There's no way around it you need the username and password
Was dit antwoord nuttig?
Score 7
2 opmerkingen:
Aw thats a shame, thanks
door Deel
new logic board will do it
door Deel
Review this Apple TN: iOS: Forgot passcode or device disabled.
In addition review this writeup by the Verge: Apple's iPhone lock stops thieves, but has unintended consequences.
Bottom line here is the phone is bricked ;-{
Score 4
Do not let Artur to mislead you ...
When your iPhone or iPad is locked it can not be unlocked by anyone, only by Apples Recover Password service!
Someone has already cheated you once when you bought this locked iPhone don't let them deceive you again here too!
Score 2
All you might be able to do is a bypass
Score 2
The person you bought it from must unlock it. There is no way around.
Score 1
Voeg je antwoord toe
Chris Roberts zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 61
Altijd: 12,547
