Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
not Chargeing after screen repair
Hi, anybody.
charge symbol get active, but do not charge after screen replacement.
phone say charging but battery still not charging... help.
dock is clean.
Is dit een goede vraag?
Score -1
4 opmerkingen
Dear Jan,
did you solve the problem?
I have the same problem... After a screen replacement battery don't charge even if the charge symbol is OK; I have not disconnected the battery connector on the logic board!!
Any tricks?
Thank you everyone in advance,
Mauro ju Macniaco
door
UAu!!
You had changed this one:
iPhone 5s Lightning Connector and Headphone Jack
I'll try to change...
Thanks
door
Mauro Macniaco did you manage to solve the problem?
I have the same issue.
Thanks,
Jake.
door
Got the same issue and perplexed as I checked connections multiple times. Is it apple rejecting the new screen hardware ?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
hi, yes i just changed the dock/charging socket/assembly.
up and running:-)
Was dit antwoord nuttig?
Score 1
Did you disconnect the battery?
3 opmerkingen:
Sounds like u have knocked or damaged a componant off the board have a look and see around the battery connector
door
yes, battery was disconnected, after disconnecting home button.
tried to reconnect again, and changed back to original display.. no charge but phone acts like it!s charging.
door
If phone acts like it's charging and isn't then it's definatly board damage
door
Voeg je antwoord toe
Jan Ove Knudsen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 252
