Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
Why does my iPod show a folder with a warning sign?
My iPod shows a folder with a warning sign and below it the words www.apple.com/support/iPod. What could the problem be and how can it be fixed?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
normally that would mean that the hard drive of the iPod needs to be replaced - any clicking sounds in the past ?
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
please click here - expecially the posting that is shown first (you should read the rest too - but this one could be important
door
since the link i wanted to add is a little bit censored, i can only recommend you a googe search with: "iPod diagnostic mode" <- use it incl. the " - the first result should give you some informations about the diagnostic mode and how to verify your harddrive without the use of a computer
door
good answer +
door
Go to www.apple.com/support/iPod like it says.
There are several different warning signs that Apple uses. Please take a look at this link: http://support.apple.com/kb/HT1378
to identify which one you have and the probable fix.
Score 1
1 Opmerking:
fresh research +
door
Why do I have a triangle warning that says NO COMMAND?
Voeg je antwoord toe
Eikel Weston zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 2,620
