Ga door naar hoofdinhoud
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
20 Vragen Bekijk alle
2012 13" MacBook Air with 2013 battery compatibility
Hi,
I got a 500 cycles battery from a 2012 13" Macbook Air and I'm thinking about replacing for a new one.
It is said on the store from this website that the 2013 13" Macbook Air battery is compatible with the mid 2012 model.
I noticed that the 2012 model has a 7.3V vs a 7.6V from the 2013 models.
Is it OK to replace it considering this voltage difference?
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Yes - that's what "its compatible" means.
If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
the description of the 2013-battery states:
"Replacement battery compatible with all 1.3 or 1.7 GHz (Mid 2013), 1.4 or 1.7 GHz (Early 2014), and 1.6 GHz or 2.2 GHz (Early 2015) 13" MacBook Airs, and backward compatible with 1.8 or 2.0 GHz (Mid 2012) 13" MacBook Air."
and that says is all.
Voeg je antwoord toe
victor hugo Cruz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,008
