Ga door naar hoofdinhoud
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
squeeling sound from under the hood
when i step on the brake pedal, i get a squeel from under the hood. any one know what this is and how to fix it
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Are you sure that the sound coming from Under the Hood and not on the brakes caliper piston? Sometimes its the friction between the back plate of the brake pads squeezing from the pression of the piston ring. On the next brake change, purchase some 'Brake Quiet paste' and apply them on the back of the brake pads frame.
I also suggest to get investigate with an mecanical technician. Sometimes, the sound comes from a different place that expected.
Was dit antwoord nuttig?
Voeg je antwoord toe
rodney zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 138
