Ga door naar hoofdinhoud
Solderen is een methode om twee stukken metaal met elkaar te verbinden door ertussen een ander toevoegmetaal te smelten. Er bestaan vele manieren van solderen, maar dit artikel is ontworpen om je de basisprincipes van elektrisch solderen te leren.
56 Vragen Bekijk alle
Looking to find out best means to learn soldering techniques
Hi everyone,
Looking to find information on the best means to learn how to solder. Often there are cases with my business I require the ability to solder. I have soldered previously however I find it frustrating when the solder does not stay on the part being soldered. I have read about adding flux and temperatures and a host of other articles which were not helpful.
How did you learn to solder?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
This is kind of like asking, "how do you ride a bicycle". Practice, practice, practice.
Start here: Soldering
Solder
Solder is used to create a non-permanent electrically conductive connection between non-ferrous metals. The relatively low melting point of lead/tin (Pb/SN) solder is a perfect match for sensitive electronic components. For applications where lead is not desired, one good substitute is "no lead" solder - usually a mixture of tin with a trace amount (0.3%) of copper. Note that most so-called "silver solders" are lead/tin with about 2% silver added. Lead-Free Solder
Stuff you may need: Soldering Workstation
Hoe moet je (de-)solderen?
Here's some more extensive reading on it: http://www.instructables.com/id/How-to-s...
Lead-Free Solder Afbeelding
Product
Lead-Free Solder
Soldering Workstation Afbeelding
Product
$49.99
Was dit antwoord nuttig?
Score 3
Utube
Thanks Brian.. Never thought of that..
Voeg je antwoord toe
new2usedcomputers zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 607
