Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Epoxy / glue for back case
The iPhone (2g) case is made of several aluminum parts that have been glued or epoxied together. The bit of aluminum that the head phone jack is screwed to came unglued from my case. Just wondering what would be the best stuff to use to reattach it?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Fix-All Adhesive is a great all-purpose solvent glue and sealer. It seals and repairs almost any surface easily and quickly. http://www.supergluecorp.com/super-glue/... FixAll
Was dit antwoord nuttig?
Score 1
I’m very far from the top of the page where you were discussing UltraDome. I have worked with epoxy resin. It yellows…I can live with that. Pretty much. But you really have to have a lot of things thought out very well beforehand or fixing it afterwards is a real DRAG!! and sometimes impossible.
http://www.parsonadhesives.com/partite-p...
Well i had used Epoxy Seam Sealers for the floor pan bonding in car, it works great. Hopefully it will solve your problem too.
Thanks for the post
Voeg je antwoord toe
scampy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,957
