Ga door naar hoofdinhoud
The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
20 Vragen Bekijk alle
Right half of touch screen not working.
Problem began with touch screen going crazy intermittently. Then right side became difficult to use, now that side is completely non-responsive. This makes it impossible to even unlock the phone. Which part of the phone contains the touch sensor? The glass/digitizer or the LCD screen itself?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Maybe there is something wrong with the flex cable of digitizer touch screen. You might have to replace the touch screen. hope you can find the new screen and its cost from here
Was dit antwoord nuttig?
if you install wondershare mobileGo ... delete the app automaticlly installed on your device or slide your right side your phone to left go to setting and turn off the sidebar...Sorry about my bad english
Voeg je antwoord toe
White zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,341
