Ga door naar hoofdinhoud
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Can I replace front panel with other colour version?
My god son dropped my iPad and front glass is completely crashed now.
I am going to order replacement parts from iFixit but I am wondering I can order other colour front panel.
I had white for almost 2 years, now it is broken and it is oppourtunity to change front colour into black, can I do this? Both colours fit to my iPad 2?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Yes, as long as you get the screen for the right model the color doesn't matter, when you order your screen you might want to also order a wifi antenna and the power volume flex, when the screen is cracked bad it's REAL tough to remove it without damaging these parts on the Ipad 2, good luck.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Ok, I've done this.
It is thin, white, plastic line around the glass, but it's hardly notable and I have a black version now.
I've also replaced wifi antenna and buttons wire, but I've broken gsm antenna...
well I can live with this :)
here is my repair story:
http://iwear.janmazurczak.pl/repair.pdf
door
Voeg je antwoord toe
Jan Mazurczak zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,672
