Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
My screen isn't working
the bottom of my screen works but the top doesn't when i touch it. so i cant get into the camera,or messages. please help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
algenelee, it is my experience, that when part of the touch does not work, the internal digitizer circuit is usually broken. The only way to fix it, will be by replacing the display assembly. They are not cheap and becoming rather scarce, so do a good search online and see what works for you. Use this guide to get it accomplished. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
algenelee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 560
