Inleiding
Don’t want to spend $1,000 on a smartphone? This year Apple brings top-tier specs to the iPhone XR so you can get all the fancy features you want for less. Did they compromise too much? Not enough? Since when is $750 cheap? There’s only one way to find out—let’s tear it down!
Follow us on Facebook, Instagram, or Twitter to keep up with all the latest teardowns. Subscribe to our newsletter to have your teardowns delivered.
Wat je nodig hebt
Video overzicht
The iPhone XR may look a little different on the outside, but the specs look pretty familiar:
Hexa-core A12 Bionic SoC with a "next-generation" Neural Engine
6.1" Liquid Retina LCD display with 1792 x 828 resolution at 326 ppi, True Tone, and wide color (P3) gamut support
12 MP rear camera at ƒ/1.8 aperture with OIS, and 7 MP selfie cam paired with TrueDepth FaceID hardware
64 GB of onboard storage (128 GB and 256 GB optional configs)
Broad cellular band support with eSIM capability and 802.11a/b/g/n/ac Wi‑Fi w/MIMO + Bluetooth 5.0 + NFC
IP67 dust/water ingress rating
Gereedschap gebruikt in deze stap:Manta Driver Kit - 112 Bit Driver Kit$69.95
There were a lot of colors to choose from, but we have an affinity for blue and black.
Colors don't matter much when you can see through anything though! Our friends from Creative Electron gave us a sneak peek at the inside of this new iPhone with some XR-ays.
Trying to stir up a bit of sibling rivalry, we stack the XR against the XS and see what differences we can spot.
We start our search at the bottom edge, where the XR's missing antenna band and nice symmetrical grilles remind us more of last year's X.
Switching on the displays, it's easy to see that the XR's bezels are a bit bigger—and if you get really close, the curves start to get a little rough around the edges.
The XR inherited a lot of features from the XS, but only got one camera—the wide-angle, while the telephoto stays with the XS.
Gereedschap gebruikt in deze stap:iOpener$19.99
Similarities to the XS continue with the opening procedure: pentalobe screws surround the not-quite-centered-anymore charging port, and opening takes just a little help from an iOpener.
Differences include: surprisingly non-color-matched pentalobe screws, and a SIM slot that slid down toward the bottom of the phone.
The thoughtful, display-first opening procedure is over with just like that—about as painless as it gets on a water-resistant smartphone.
Inside, the XR starts to look more like a fun hybrid between the 8 and the X. We're back to a rectangular battery, but there's also a rectangular logic board.
The question is: How many layers does that logic board have?
Gereedschap gebruikt in deze stap:Standoff Screwdriver for iPhones$5.49
On the way to freeing up the logic board, we're encountering a veritable plethora of standoff screws. We're used to one or two per iPhone, not
Xten. -
Luckily, we're armed and ready.
What's this? A modular SIM card reader! That's an iPhone first.
This is likely a concession to the Chinese market, where eSIM is not supported—so in order to enable dual-sim functionality on Chinese models, Apple installs a dual Nano-SIM reader. The modular approach makes this much easier than it would be if the reader were soldered to the main board, as in past models.
The svelt, non-elbowed, single-decker logic board is now free to escape!
With a modular Sim Reader, could it be we can swap the EU one for the Chinese sim reader and leverage true dual-sim? That would be excellent!
I agree reason of modularity should be there. But I suppose is more an issue of industrialize with efficiency. Sound difficult that it would work on the ESim board ..? 3 Sim sound too much …. but is some to investigate. it may happen they put ESim hardware all over and that dual physical sims may come out swapping the modules… Thinking they have done it because sharing an advantage with users I doubt about. Is since 3 years that more and more components in the Apple lineup are soldered and not changeable and its obvious that a relevant part of their stellar margins came from an accurately strategy that consider ram sizes… or hd in the Mac arena…
With the logic board out, we get our first look at the onboard silicon:
Apple APL1W81 A12 Bionic SoC, layered over Micron MT53D384M64D4SB-046 XT:E 3 GB LPDDR4x SDRAM
Apple/USI 339S00580 (likely a WiFi/Bluetooth module, similar to what's found in the XS)
NXP Semiconductor SN100V NFC controller
3x Apple/Cirrus Logic 338S00411 audio amplifiers
Skyworks 203-15 G67407 1838 (likely a power amplification module)
Infineon (formerly Cypress Semiconductor) CYPD2104 USB type-C port controller
Qorvo QM76018 RF Front End Module
The “76018 119G1“ module is the Qorvo PAD.
More chips on the back side of the logic board. Show us your identification, please...
Toshiba TSB3243VC0428CHNA1 64 GB flash storage
Intel PMB9955 (likely the XMM7560 LTE Advanced Pro 4G LTE baseband processor), PMB5762 RF transceiver, and PMB5829
Apple 338S00383-A0, 338S00375-A1 power management IC's (possibly from Dialog Systems)
Texas Instruments SN2600B1 battery charging IC
Apple/Cirrus Logic 338S00248 audio codec
Skyworks SKY13768 front end module
Broadcom BCM59355A2IUB4G (likely a variation of the BCM59350 wireless power receiver chip)
IC Identification, pt 2.
Texas Instruments LM3539 backlight driver
NXP Semiconductor CBTL161x display port multiplexer (likely)
STMicroelectronics STB601A0 power management
Texas Instruments TPS65730 display power management
Texas Instruments LED driver (likely)
Bosch Sensortec BMP282 pressure sensor
Bosch Sensortec accelerometer
Moving on from the logic board, here are two more logic boards.
The new XR board + SIM reader (center) looks a bit like an unfolded iPhone X board (right). The sprawling iPhone 8 Plus board is shown at left for comparison.
This new form factor pretty much perfectly fills the gap in the evolution of iPhone logic boards.
A closeup via X-rays reminds us that this "simplified" iPhone logic board is still enormously complex.
Even more silicon hides beneath other components, like the TrueDepth camera system.
All four tabs perform admirably, and the 11.16 Wh battery is removed goo-free!
We've already heard that the XR has the best iPhone battery life yet, but just how does it stack up? Time for a battery parade!
Left to right, we have: iPhone 8 (6.96 Wh), iPhone XR (who is #winning), iPhone 8 Plus (10.28 Wh), and iPhone XS (10.13 Wh).
If you're looking for an Apples-to-oranges comparison, Android is still winning the pure capacity game. The Galaxy S9+ remains champion at 13.48 Wh, and the Pixel 3 XL follows closely at 13.2 Wh.
While we're stacking, let's take the opportunity to X-amine some X-series X-rays. Left to right, we have the iPhone X, the XR (with its less-dense aluminum frame), and the XS Max!
Why is the iPhone X’s induction coil wire so much thicker than the others? Was that a change from the 8/X to XR/XS generations?
@unitof Correct—Apple redesigned their charge coils for this year’s models. Word is they are using copper coils (as seen in the steps below) rather than ferrite polymer composite (FPC). Good eye!
Here’s the single rear camera—the same newly-updated wide-angle module from the XS and XS Max.
We line the camera up alongside the TrueDepth system powering FaceID—which, as far as we can tell, looks pretty much unchanged from when we first saw it in the iPhone X.
Not to be left behind, the lower speaker is next—it's still pretty easy to remove, which is good, because you’ll probably want it out of the way for a battery replacement.
Next we turn our attention to Apple’s much-discussed Liquid Retina display.
The XR’s LCD is 0.3” larger across than the XS’s AMOLED, but it’s also thicker and heavier—as is expected from an LCD.
As far as we can tell, this thicker display assembly is what has pushed the Lightning connector off-axis.
Getting back into the case, we dig out the wireless charging coil for a closer look.
We’ve struck copper! Copper’s lower resistance (compared to FPC in the X) should mean faster charging with less heat.
Is the touch panel separate or incell?
i didn’t notice the lightning connector being off axis. %#*@ it, now i can’t unsee it. that is going to bug me all day.
With the XR fully excavated, we display the tidbits from our dig:
Thanks again to our good friends at Creative Electron. Now we'll leave you with a really good joke:
What's a pirate's favorite iPhone?
The X-ARRRrrrrr
Muy bueno el chiste, favorito desde ahora de mi hijo de 7 años. =)
- The display-first opening procedure and easy access to the battery remain design priorities.
- A broken display can be replaced with minimal hardware removal, and with a little care you can preserve Face ID.
- Apple again uses tiny uncommon Pentalobe and tri-point screws to stymie repair, but these fasteners are preferred over tough glue.
- Waterproofing measures complicate some repairs, but make difficult water damage repairs less likely.
- Glass on front and back doubles the crackability—and broken back glass requires an entire chassis replacement.
Laatste gedachten
Repareerbaarheidsscore
(10 is gemakkelijkst te repareren)
43 opmerkingen
Next year: iPhone XR GTS SS Z11 LX
iPhone XR GTS SS Z11 LX Turbo Limited Luxury 2.0 Edge
Robert G -
I think it’s thicker
It’s stated that it’s thicker. There are more than 2 dimensions.
Because Xr’s battery is thicker
drbranco -
Hi I’m wondering how much difference is there between the Taptic Engine’s iPhone Xs and Xʀ have?
Hey Houston, the XR and XR Taptic engines look nearly identical size-wise, but have different screw patterns!
Are there any Himax Technology parts in this phone?
I was in the Higuera Apple Store when Kiki bought this phone! She bought a coral one too.
Who’s Kiki lol?
Rafael B -
Did I miss the Teardowns wallpaper?
I wonder if you can switch out the sim slot with the dual sim slot of the Chinese version and get a real dual sim upgrade.
That would be really cool!
indeed. Is the ST33G1M2 e-sim chip in the sim-reader module or in the motherboard?
If we could replace the sim-reader for true dual-sim it would be excellent!
Yes a proper dual sim would really reduce the aggro from providers. One thing has always bothered me about these glued shut phones: What happens to the waterproofing once you have opened one using an iopener or similar soource of heat? When reassembled, will they still be waterproof? (almost certainly not?)Could you remove the old sealant and rewaterproof it properly? What would you use?
Actually, the “juice” in the battery means very little to the user. What user cares more are:
1. Can I leave home without a charger, and without hoping for a charger until I come back?
2. What performance can I expect with such battery? (in simple words - Can I run latest 3d jaw-dropping 120fps game on the device without draining it in half an hour? Will I survive a 3 hour drive with navigation software running, without a charging cable?)
3. How much do I pay for this battery, in weight? After all - anyone can stick an accessory battery and have their iPhone work for 2-3 days. Only it’s… well… heavy!
So the battery parade isn’t very helpful - and as far as my own experience taught me - Androids with huge battery, still drain twice as fast as my old iPhone SE - while presenting mediocre, never-awe-inspiring performance.
I wish someone would come up with a GOOD benchmark on power and up-time on those iPhones.
Yes, I’m an iOS software developer - I KNOW apps can kill battery and Apple can’t prevent this completely.
It is true that battery capacity is only one of many influencers of how long a phone will last.
Here’s an article that compares how long phones last browsing the web before they die.
It’s much better that it’s iPhone 8 siblings….
I mean, once you got all the screwdrivers you need, all you have to worry about is the way to pull off that display.
Lightning connector IS still modular. Unlike the other *cough* iPad *cough* lineup.
Can i just say, i love your teardown and everything, but its been 8 years now that Apples been using pentalobe screws, and i think that the pentalobe driver has become quite common (most repair kits you buy, either from iFixit or for $2 off of amazon have a pentalobe driver), so i don’t think it merits being in the “neutral” section of the repairability criteria…
Hey, Andrew, thanks for reading and commenting! Glad you enjoy the teardowns! I agree that pentalobe and tri-point drivers are more widely available now than they were eight years ago, but pentalobe and tri-point screws still aren’t used anywhere besides Apple devices. That means that even someone who’s equipped to take apart all other electronics has to order special drivers to work on Apple products, and we view that as a move toward keeping people out of their devices.
where the iPad Pros at?
It would be nice to see more details of the how the LCD screen is connected to enable the symmetrical bezel, and how it differs from the curved OLED bottom of the X series screens.
What about the shield on the back of the screen that is welded down is that need to swap the screen?
Big question that NO ONE ever mentions, How about the back CAMERA glass on the XR??? The small piece of glass over the lens of the camera? I see the part for sale for only $7 and by the looks and feel of it, its a separate piece!
Does anyone knows where is the logic board’s serial number?
Anyone ever facing a problem with eSIM module?
This is a horrible teardown, I love this website and have used it for close to 7 years. Most teardown’s on here are great and give all the details on parts and screws but this one is stupid. This phone has been out for over a year, can we get a more detailed teardown please. I am sorry if I am being a jerk in this comment.
I’m sorry this one wasn’t up to par for you Jon! :( Could you elaborate on what you mean by more detailed? What specific things would you like to see in this (and other) teardown(s)? We’ve been doing our best to keep teardowns fun and exciting while phones are getting more and more similar, but we definitely have skipped over some important things from time to time in our attempt to avoid rehashing details. I’d love to hear your thoughts, thanks for loving our website and being a follower for so long!
Where is the NFC antenna please? After a frame replacement, the induction charge works but not Apple Pay, any idea ? Thanks
They put the long ones on YouTube … I guess to get Remuneration $$$ - OK, I understand.
JoeBlog -
what about bottom? where is plug for charger ?
Hi, is it possible to buy from iFixit replace microphone for iPhone XR please? I am in Denmark and which other's products for finish correct replace the port microphone I need also?
