Ga door naar hoofdinhoud
Midiman Oxygen 8 Potentiometer Removal Teardown
Stap 4 vertalen
Engels
Nederlands
Stap 4
Midiman Oxygen 8   Potentiometer Removal Teardown: stap 0, afbeelding 1 van 2 Midiman Oxygen 8   Potentiometer Removal Teardown: stap 0, afbeelding 2 van 2
  • Once the retaining nuts and screws are removed, the circuit board with the attached potentiometers will easily separate from the front plate.
  • To replace the damaged potentiometer, de-solder the three connections, replace with a new potentiometer, and re-solder the connections.
Vertaling hier toevoegen
