Ga door naar hoofdinhoud
Asus Zenfone 2 Teardown
Engels
Nederlands
Stap 3
Asus Zenfone 2 Teardown, Removing the motherboard: stap 0, afbeelding 1 van 3 Asus Zenfone 2 Teardown, Removing the motherboard: stap 0, afbeelding 2 van 3 Asus Zenfone 2 Teardown, Removing the motherboard: stap 0, afbeelding 3 van 3
  • Remove the copper tape adhered to the mid-frame. The motherboard is held to the mid-frame using 4 plastic clips. I found that starting to pry up the motherboard from the right is easier than from the left. Just apply mechanical sense and you will get the motherboard out in no time.
  • Make sure not to bend the motherboard from too much pressure.
Vertaling hier toevoegen
