Ga door naar hoofdinhoud
Amazon Echo Dot Teardown
Stap 13 vertalen
Engels
Nederlands
Stap 13
Amazon Echo Dot Teardown: stap 0, afbeelding 1 van 2 Amazon Echo Dot Teardown: stap 0, afbeelding 2 van 2
  • Amazon Echo Dot Repairability Score: 6 out of 10 (10 is the easiest to repair)
  • The majority of the device is held together by standard Torx screws.
  • Many components are common to the original Echo, making it easier to source parts.
  • The rubber foot, base cap, and speakers are held in place with tough adhesive.
  • The headphone jack and USB port, two common points of failure, are soldered directly to the motherboard.
Vertaling hier toevoegen
