Ga door naar hoofdinhoud
Canon PowerShot S400 Teardown
Stap 1 vertalen
Engels
Nederlands
Stap 1
Canon PowerShot S400 Teardown: stap 0, afbeelding 1 van 2 Canon PowerShot S400 Teardown: stap 0, afbeelding 2 van 2
  • The flash capacitor stores high voltage and can cause an electrical shock. Handle with extreme caution.
  • Working with the lens-flash assembly, remove the three 3.45mm screws located on the metal plate.
  • Separate the flash assembly from the lens assembly.
  • Set aside the flash assembly in a safe location.
Vertaling hier toevoegen
