Ga door naar hoofdinhoud
iPhone 4 Teardown
Stap 27 vertalen
Engels
Nederlands
Stap 27
iPhone 4 Teardown: stap 0, afbeelding 1 van 1
  • iPhone 4 Repairability Score: 6 out of 10 (10 is easiest to repair)
  • The iPhone 4 is held together primarily with [lots of] screws, sans tabs, and limited adhesive.
  • The rear panel and battery are both easy to remove and replace (provided you have the right kit and/or correct screwdriver).
  • Apple is using Pentalobe screws to secure the rear panel and keep people out.
  • The LCD and glass are fused together, making repairing a cracked front panel more costly.
  • During disassembly, your finger oils interfere with the iPhone 4's RF grounding contact points, so we recommend you wear gloves while performing any repairs.
Vertaling hier toevoegen
