Ga door naar hoofdinhoud
LG G2 Teardown
Engels
Nederlands
Stap 2
LG G2 Teardown: stap 0, afbeelding 1 van 2 LG G2 Teardown: stap 0, afbeelding 2 van 2
  • Starting from the bottom corner, use the thin blunt side of a Spudger to separate the back from the metal bezel. THIS CAN CAUSE COSMETIC & INTERNAL DAMAGE if you are not careful.
  • Use a thumb nail, plastic spudger, or pry tool to raise one side releasing the plastic clips. Then raise the other side and the top should pull off with ease.
  • During reassembly the back may fight a little to go back on. Start from the side and go around do not be afraid to pinch it with a little muscle.
Vertaling hier toevoegen
