Ga door naar hoofdinhoud
iPad Mini 2 Teardown
Stap 17 vertalen
Engels
Nederlands
Stap 17
iPad Mini 2 Teardown: stap 0, afbeelding 1 van 2 iPad Mini 2 Teardown: stap 0, afbeelding 2 van 2
  • iPad Mini Retina Display Repairability: 2 out of 10 (10 is easiest to repair).
  • The LCD and glass are not fused together and can be replaced independently.
  • The battery is not soldered to the logic board or other components.
  • Teeny-tiny screws can be easily misplaced if you're not careful. Don't sneeze too hard while taking them off.
  • Copious amounts of adhesive hold many components in place—front glass, battery, front camera, back camera, ribbon cables—making repair extremely difficult.
  • The Lightning connector is soldered to the logic board, so don't bend its pins.
  • Hidden screws mean you'll need to be very diligent when trying to remove internal components.
Vertaling hier toevoegen
