Ga door naar hoofdinhoud
Nokia Asha 200 Teardown
Engels
Nederlands
Stap 4
Nokia Asha 200 Teardown: stap 0, afbeelding 1 van 2 Nokia Asha 200 Teardown: stap 0, afbeelding 2 van 2
  • The lcd screen is held in by a steel bracket. This bracket is held in place by the clips marked with red squares. The easit way to release it is by levering the one on the right (as pictured) and the bracket should come off.
  • When re-assembling make sure the studs marked with blue circles line up properly.
  • Using a spudger disconnect the LCD cable.
Vertaling hier toevoegen
