Ga door naar hoofdinhoud
Nokia Asha 200 Teardown
Engels
Nederlands
Stap 2
Nokia Asha 200 Teardown: stap 0, afbeelding 1 van 3 Nokia Asha 200 Teardown: stap 0, afbeelding 2 van 3 Nokia Asha 200 Teardown: stap 0, afbeelding 3 van 3
  • Insert spudger between the front/back case and lever untill you hear a click.
  • Slowly work your way around until the bottom end is separated. Then with the bottom end facing your body, try to pull the back case towards yourself.
  • Make sure not to loose Sim2 and Micro SD covers as they easily fall out. Also when re-assembling make sure they are pulled out otherwise you will have trouble putting things back together
Vertaling hier toevoegen
