Ga door naar hoofdinhoud
This IDES2323 Task2 teardown assignment was done by industrial design student Yuanhang Yan. The item disassembled is the Schick - Hydro 5 Groomer Kit for Men, 4-In-1 Power Trimmer. This post will go into detail about the inner workings of this Groomer Kit.
Wat je nodig hebt
iFixit krijgt commissie als je dingen koopt via deze links.
Deze demontage is geen reparatiehandleiding. Om je Schick Hydro 5 Groomer Kit 4 in 1 te repareren, gebruik onze reparatiehandleidingen.
  1. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, GroomerKit Overview: stap 1, afbeelding 1 van 2 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, GroomerKit Overview: stap 1, afbeelding 2 van 2
    • Schick - Hydro 5 Groomer Kit for Men, 4-In-1 Power Trimmer
    • The box contains: AA battery, four replacement razor heads, GroomerKit.
  2. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Open the battery compartment: stap 2, afbeelding 1 van 1
    • Simply pull the top and bottom of the GroomerKit apart to open it.
  3. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part: stap 3, afbeelding 1 van 2 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part: stap 3, afbeelding 2 van 2
    • The Shaver Part has a replaceable Razor head, just press the white button on the front and the Razor head comes off automatically.
  4. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part-Battery Compartment: stap 4, afbeelding 1 van 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part-Battery Compartment: stap 4, afbeelding 2 van 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Shaver Part-Battery Compartment: stap 4, afbeelding 3 van 3
    • Open the battery compartment of the Shaver Part begins with cutting the outer wrapping of silicone along the red line with a knife.
    • After removing the silicone layer you will see the internal battery compartment structure, next you just need to use a screwdriver to press down the metal part inside the red circle to remove the battery compartment smoothly.
    • It took me a long time to disassemble the razor section, which appears to have a molded case and was designed with the intention of never opening it again.
  5. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: stap 5, afbeelding 1 van 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: stap 5, afbeelding 2 van 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: stap 5, afbeelding 3 van 3
    • The protective part of the Trimming part simply comes off by pushing your thumb along the red line position.
    • The blade part of the Trimming part simply comes off by pushing your thumb along the red line position.
    • The position shown by the circle in the picture is where the output of the motor is located, and this metal bar will always make a clockwise movement.
  6. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: stap 6, afbeelding 1 van 2 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part: stap 6, afbeelding 2 van 2
    • The Trimming Part works by constantly moving the blade from side to side to cut the hair.
    • Open the Trimming Part begins with cutting the outer wrapping of silicone along the red line with a knife.
  7. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part-Motor: stap 7, afbeelding 1 van 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part-Motor: stap 7, afbeelding 2 van 3 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Trimming Part-Motor: stap 7, afbeelding 3 van 3
    • Once you open the silicone skin you can see the circuit board part of the button.
    • Since the outer layer of the Trimming Part circuit board's outer layer is made up of three layers of plastic tightly wrapped together, I attempted to use a drill bit to open up the entire enclosure, but that ended in failure.
  8. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Motor internal schematic: stap 8, afbeelding 1 van 2 Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown, Motor internal schematic: stap 8, afbeelding 2 van 2
    • Since I couldn't open the inner structure, I drew pictures of the inner structure.
    • The second image is from the web, this one shows a similar internal structure.
  9. Schick Hydro 5 Groomer Kit 4 In 1 Power Trimmer Teardown: stap 9, afbeelding 1 van 1
    • All disassembled parts of the Groomer Kit.
Oliver Yan
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 396
