Ga door naar hoofdinhoud
Deze demontage is geen reparatiehandleiding. Om je HP Compaq te repareren, gebruik onze reparatiehandleidingen.
    • Use the latch on the side panel to open it
    • Make sure you open the panel, pulling up and pulling towards your self as shown in the pictures
    • Removing drives is easy, just pull the drive bay up and you can access them
    • Fallow the next step if your hard drive is the OEM hard drive, it has a different placement (under the power supply.
    • Be carful around the SATA cables so you don't cut them!!!
    • You may now remove / replace any disks in the shown area
    • Lift the power supply up in the direction of the green arrow
    • Remember !!!!ALWAYS UNPLUG YOUR DEVICE BEFORE OPENING!!!!!!!
    • Just disconnect the cables going to the floppy, cd/dvd, and hard drive. (: Great Job so far
    • Be carful around wires (Don't cut or damage)
    • Just go slow and take your time (;
    • CAUTION (There are 2 screws on both sides of the DVD/CD drive)
Ethan Eimont
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 113
