Ga door naar hoofdinhoud
« Terug naar alle verhalen
Fixing the devastating Custom OS screen.
Kyeler W -
Samsung Galaxy A14
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
Samsung Galaxy A14 Screen Replacement
25 minuten
Moderate
Mijn probleem
After moving my internals to the new casing, I keep encountering this screen (second image) after connecting the battery to the motherboard. The volume button would not detect the right input. I cleaned the volume buttons multiple times and nothing worked.
Mijn oplossing
I figured out the problem. My new casing didn't have the part in the square glued to the case, it was lifted up and flopping around. It took me a while to realize, but it isn't supposed to be on top of the motherboard; it's supposed to rest under it.
Mijn advies
Make sure everything looks in place and compare it to your previous casing; you might save yourself the 20 minutes I sacrificed to fiddling around with volume buttons.
1 Opmerking
good job dear
Sara Mah - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 315
