Ga door naar hoofdinhoud
« Terug naar alle verhalen
iPhone 15 Battery Replacement
Kalie Brunton -
iPhone 15
Afbeelding van het verhaal
2 uren
Moderate
Mijn probleem
The phone was dropped and the back glass cracked and also damaged the battery, which was swollen.
Mijn oplossing
The battery repair went smoothly. It took under an hour, including the time to separate the back glass from the screen.
Mijn advies
Sometimes the batteries (the originals especially) can be a pain to remove from the phone. The adhesive is no joke. I use an iFixit iOpener to lay over the battery and heat up the adhesive, and then use an opening pick to pry it up. Slow, consistent pressure is the way to go.
iOpener Afbeelding
iOpener
$24.95
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 148
