Ga door naar hoofdinhoud
« Terug naar alle verhalen
N64 Controller Cleanup
Chayton Ritter -
Nintendo 64 Controller
Afbeelding van het verhaal
  • Afbeelding #1
  • Afbeelding #2
  • Afbeelding #3
Nintendo 64 Controller Joystick Repair
45 minuten
Moderate
Mijn probleem
I took a trip to my local Goodwill and found this rather sad-looking N64 controller. It was covered in dust and grime from some previous extreme gaming sessions. The joystick was also a little crusty and scratchy.
Mijn oplossing
To start, I fully disassembled the controller to see what I was working with. The case was covered in a layer of gamer gunk but other than some minor dust the insides were pretty clean. Continuing, I removed all the components from the shell so I could clean them. I also disassembled the joystick module to fix the scratchyness.
All the parts got a bath in my ultrasonic cleaner with dish soap and warm water. This tool is awesome and works wonders at grime removal. After their bath, I blasted all the parts with my air compressor to dry them.
Reassembly was a breeze, especially the buttons because they are keyed and can't be mixed up. The joystick module needed more attention because there was some crust stuck to the bottom. I cleaned up the crust, applied some fresh grease, and then put it back together.
Now I have an almost pristine N64 controller to enjoy.
Mijn advies
Use a magnetic mat and parts tray together to keep track of screws and pieces. Staying organized makes disassembly, reassembly, and troubleshooting so much easier.
Anti-Static Project Tray Afbeelding
$6.95
1 Opmerking
noice cleanup, i ussually flip profits using this method at my local flea market🫡
Tran Anh Khoa (Kyle) - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 556
