Ga door naar hoofdinhoud
« Terug naar alle verhalen
Repair is noble
hambachw -
iPod Classic
iPod Classic Headphone Jack & Hold Switch Replacement
45 minuten - 2 uren
Very difficult
Mijn probleem
I take my iPod to bed - and on a certain day the headphone jack got twisted - and damaged my iPod internally. So: no more music. It was a very very sad day. The most economic way to fix this was to order the required spare parts and tools and do it myself. (If others can do it, I can do it too)
Mijn oplossing
Repair went fine but I took my time: about an hour. I Read the instructions thoroughly.
Removing the cover without damaging/bending it was the hardest part. I did not use the plastic opening tools - they were no real help.
Mijn advies
Take your time and concentrate. Remove tape over cables slow and gently. Watch carefully that the flat cables remain flat - I had a small problem with that. The new cable was bent next to the headphone jack and this resulted in a very distorted sound.
At that point I thought : "My GOD, what have I done!?".
Gently straightening the cable solved the issue and my iPod was as new. Then I taped the cables back on their original places.
Tip 1: order the required tools.
Tip 2: Test your iPod while it is still open, if anything went wrong - you can easily look for the problem without the need to reopen the thing.
Tip 3: keep cats, spouses and children away from the operation quarter.
Couldn't have done it without iFixit though, big thanks guys!
iPod Classic (Thin) Headphone Jack & Hold Switch Afbeelding
$9.99
Spudger Afbeelding
Spudger
$3.99
Phillips #00 Screwdriver Afbeelding
$5.49
Metal Spudger Afbeelding
Metal Spudger
$2.99
iFixit Opening Tool Afbeelding
iFixit Opening Tool
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 156
