Mijn probleem
A broken screen.
Mijn oplossing
I have lost over 75% vision on my right eye, so I was a bit worry with the tiny screws, but with a little patience the job was done in less than 15 minutes. I had a problem with the suction cup not grabbing the screen, I added clear packing tape but I was not careful enough to take all the tiny bubbles, so the cup didn’t stick. Re-taped without air-bubles and voila!!!
Mijn advies
Work in a clean well lit area.
Follow the steps in the repair guide.
If the suction cup is not sticking, cover the broken glass with clear packing tape ensuring there are not air bubbles under it, the cup will stick. You need only a tiny lift for the plastic opening tool to grab.
Careful no to lose the screws. Take your time when reinstalling them, I used both hands to put the head of the screw on the screw-driver before dropping it into the hole.
The connectors are a bit ackward to align, be careful not to damage them, take your time.
0 opmerkingen
