Ga door naar hoofdinhoud
iPod Touch 5th Generation Battery Replacement
Fix It Planet
Fix It Planet en een andere bijdrager
Voor het laatst geüpdatet op January 25, 2025
30 minuten
Gemiddeld
Door de gemeenschap gemaakte handleiding
iPod Touch (A1421) 5th Gen Battery Replacement From Start To Finish. (Video Guide With Explanation)
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
    • Follow this video guide from start to finish and enjoy!
Conclusie
Did you follow all the steps? Yes! Then enjoy!
29 andere personen hebben deze handleiding voltooid.
Fix It Planet
1.585 Reputatie
3 handleidingen geschreven
23Gids Commentaar
The solder in the video looks like a clear liquid, I’m I missing something. I’m used to solder that looks like wire? Is there something new that is easier to use?
Thanks for putting this up, I’m trying to decide if I can do the soldering and I just want to make sure I know what I’m getting myself into.
Joshua Edwards - Antwoord
Sorry for the confusion. That clear liquid is actually flux. The solder has been put on the iron tip prior to soldering the pads. Not much solder is needed but the flux is necessary to help the flow and bonding of the solder.
Fix It Planet - Antwoord
What kind of wick do you use?
Nick DeRissio - Antwoord
Goot wick. Model: CP - 2015 Width: 2 mm
Fix It Planet -
Could I use an IOpener tool to open the ipod?
Best Songs - Antwoord
Yes you can use any opener that you prefer.
Fix It Planet -
Yes, you can use an iOpener.
Ultra -
The existing battery in my iPod Touch 5th Generation only lasts about 30 minutes per charge, and Apple wants $80 to replace it? No way!
patdiddy - Antwoord
John - VERY nice and helpful video. I wish I’d had the iSesamo opening tool that you used. I got it open but dinged the case a bit with the larger tools that were in my iFixit tool kit.
It also took longer than I’d hoped but I was successful at it. Also, where can one purchase the double-sided adhesive to keep the new battery down?
I’m very pleased with the result of the battery replacement and once again, your video was terrific. I had it on a 27” Cinema display right on the table where I did the work.
Thanks,
Rob Reider
Cincinnati
May 10, 2019
Rob Reider - Antwoord
Hi Rob, Thank you!
I’m happy the video is useful.
You can get some 5mm 3M 300LSE here https://amzn.to/2VVtN1J
Cheers!
Fix It Planet -
Thanks, John. I’ll order some up when I get my next “project!” Best success to you, sir.
Rob
Hi, I am wondering if you lose all of your data and settings when you disconnect the old battery. Thank you for the great video and thank you for your time regarding my question. Jay Scott
Jay Scott - Antwoord
If data is important then It is always best to back up the data prior to any repair attempt (if possible). Having said that, I have not yet experienced data loss from replacing the battery on any device. This does not mean it is impossible, for example; if the device is damaged during the repair attempt in such a way you cannot gain access to the data that would be a problem. Hope this helps. cheers
Fix It Planet -
thank you you are a good teacher
antonio pagan - Antwoord
What temperature do you set on the heat gun to detach the home button safely?
Thierry Coton - Antwoord
If your using a heat gun set it on low and keep it moving. Not much heat is needed or you could burn the display.
Fix It Planet -
I actually used my rework station at minimum temp (100°C) and it was OK. The hardest part was to de-solder the battery!!
Thierry Coton -
Video is not playing from YT (YT issue? probably). Other than the iPod 5th Gen teardown, looking for other pictorial guides that can be used.
David Spalding - Antwoord
Looks like a bit more detail is needed. At least for my iPod touch I appear to need a Phillips #000 screwdriver as outlined in this tutorial: iPod Touch 5th Generation LCD Shield Plate Replacement
Also looks like this needs to be a fairly high quality screwdriver as I have a “cheapo” here and it isn’t fine enough to get into the screw head.
Lloyd Moore - Antwoord
At the second replacement of the battery I had the misfortune of broken solderpads for the + and - connection.
Can anyone tell me if there is a possibility to find connction for +&- on a nearby place on the printplate
Reijk den Held nl. 10-11-20
reijk - Antwoord
Does the board have 2 dots on the solder pads like the battery cable? I'm seeing the 2 dots on each pad as if the old battery pads are still there. Do I just clean up and solder over or try to remove them? Several attempts to remove the “2 hole pads" and they dont want to come off. Thank you.
Brett Veenstra - Antwoord
Hello i saw your video but could you tell me whats Is ir whats is mame of “tape" you use and the end of video to cover “pins"? It Is color yellow, of course for me your video Is helpfull thanks
Jose - Antwoord
Hi Jose it is called "Captan Tape" and is heat resistant.
Steve Clen-Murphy -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 85
Afgelopen 30 dagen: 438
Altijd: 43,437
