Ga door naar hoofdinhoud
iPhone SE 2020 LCD and Digitizer Replacement
Wat je nodig hebt
  1. iPhone SE 2020 LCD and Digitizer Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone SE 2020 LCD and Digitizer Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone SE 2020 LCD and Digitizer Replacement, Tape over the display: stap 3, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement, Tape over the display: stap 3, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement, Tape over the display: stap 3, afbeelding 3 van 3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  4. iPhone SE 2020 LCD and Digitizer Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone SE 2020 LCD and Digitizer Replacement: stap 5, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 5, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone SE 2020 LCD and Digitizer Replacement: stap 6, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 6, afbeelding 2 van 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone SE 2020 LCD and Digitizer Replacement, Heat the display: stap 7, afbeelding 1 van 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  8. iPhone SE 2020 LCD and Digitizer Replacement, Separate the display: stap 8, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement, Separate the display: stap 8, afbeelding 2 van 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  9. iPhone SE 2020 LCD and Digitizer Replacement: stap 9, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 9, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 9, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone SE 2020 LCD and Digitizer Replacement: stap 10, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 10, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 10, afbeelding 3 van 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  11. iPhone SE 2020 LCD and Digitizer Replacement, Screen information: stap 11, afbeelding 1 van 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone SE 2020 LCD and Digitizer Replacement: stap 12, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 12, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 12, afbeelding 3 van 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone SE 2020 LCD and Digitizer Replacement: stap 13, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 13, afbeelding 2 van 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  14. iPhone SE 2020 LCD and Digitizer Replacement: stap 14, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 14, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 14, afbeelding 3 van 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  15. iPhone SE 2020 LCD and Digitizer Replacement: stap 15, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 15, afbeelding 2 van 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  16. iPhone SE 2020 LCD and Digitizer Replacement: stap 16, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 16, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 16, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  17. iPhone SE 2020 LCD and Digitizer Replacement, Disconnect the battery: stap 17, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement, Disconnect the battery: stap 17, afbeelding 2 van 2
    Magnetic Project Mat
    $19.95
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
  18. iPhone SE 2020 LCD and Digitizer Replacement: stap 18, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 18, afbeelding 2 van 2
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  19. iPhone SE 2020 LCD and Digitizer Replacement, Disconnect the display and digitizer: stap 19, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement, Disconnect the display and digitizer: stap 19, afbeelding 2 van 2
    • Use the point of a spudger to pry the lower display connector out of its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  20. iPhone SE 2020 LCD and Digitizer Replacement: stap 20, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 20, afbeelding 2 van 2
    • Use the point of a spudger to disconnect the second lower display cable.
  21. iPhone SE 2020 LCD and Digitizer Replacement: stap 21, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 21, afbeelding 2 van 2
    • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
  22. iPhone SE 2020 LCD and Digitizer Replacement: stap 22, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 22, afbeelding 2 van 2
    • Use the point of a spudger to disconnect the front panel sensor assembly connector.
  23. iPhone SE 2020 LCD and Digitizer Replacement, Remove the display assembly: stap 23, afbeelding 1 van 1
  24. iPhone SE 2020 LCD and Digitizer Replacement, Remove the home/Touch ID sensor bracket: stap 24, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement, Remove the home/Touch ID sensor bracket: stap 24, afbeelding 2 van 2
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.2 mm screw
    • Remove this screw first. Excess pressure may bend the home button bracket if you remove the 1.3mm screws first.
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
  25. iPhone SE 2020 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: stap 25, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: stap 25, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: stap 25, afbeelding 3 van 3
    • Use an opening tool to pry under the left edge of the home button cable connector to disconnect it from its socket.
    • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat end of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
  26. iPhone SE 2020 LCD and Digitizer Replacement, Remove the Touch ID sensor: stap 26, afbeelding 1 van 1
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
    • Don't overheat the display. It should be slightly too hot to touch comfortably.
  27. iPhone SE 2020 LCD and Digitizer Replacement: stap 27, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 27, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 27, afbeelding 3 van 3
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
  28. iPhone SE 2020 LCD and Digitizer Replacement: stap 28, afbeelding 1 van 1
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display as shown.
    • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
  29. iPhone SE 2020 LCD and Digitizer Replacement, Remove the earpiece bracket: stap 29, afbeelding 1 van 1
    • Remove the three Phillips screws securing the top earpiece bracket to the front panel:
    • Two 2.6 mm screws
    • One 1.8 mm screw
  30. iPhone SE 2020 LCD and Digitizer Replacement: stap 30, afbeelding 1 van 1
    • Remove the earpiece speaker bracket.
  31. iPhone SE 2020 LCD and Digitizer Replacement, Move the front-facing camera: stap 31, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement, Move the front-facing camera: stap 31, afbeelding 2 van 2
    • Lift the front facing camera up out of its socket and swing it out of the way.
  32. iPhone SE 2020 LCD and Digitizer Replacement, Remove the earpiece speaker: stap 32, afbeelding 1 van 1
    • Remove the two Phillips screws securing the earpiece speaker to the front panel:
    • One 1.8 mm screw
    • One 2.3 mm screw
  33. iPhone SE 2020 LCD and Digitizer Replacement: stap 33, afbeelding 1 van 1
    • Remove the earpiece speaker.
  34. iPhone SE 2020 LCD and Digitizer Replacement, Remove the front camera and sensor cable: stap 34, afbeelding 1 van 1
    • Heat an iOpener and apply it to the upper edge of the display to soften the adhesive holding the front camera and sensor assembly in place.
    • Wait about two minutes before moving on to the next step to adequately soften the adhesive.
  35. iPhone SE 2020 LCD and Digitizer Replacement: stap 35, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 35, afbeelding 2 van 2
    • Use the point of a spudger to gently pry the proximity sensor out of its recess on the front panel.
    • Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
  36. iPhone SE 2020 LCD and Digitizer Replacement: stap 36, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 36, afbeelding 2 van 2
    • Slide the tip of a spudger underneath the ambient light sensor flex cable, and lift the sensor out of its housing.
  37. iPhone SE 2020 LCD and Digitizer Replacement: stap 37, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 37, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 37, afbeelding 3 van 3
    • Slide an opening pick underneath front camera cable assembly, separating the adhesive holding the camera and sensor cable.
  38. iPhone SE 2020 LCD and Digitizer Replacement: stap 38, afbeelding 1 van 1
    • Remove the front camera and sensor cable.
  39. iPhone SE 2020 LCD and Digitizer Replacement, Separate the LCD and digitizer: stap 39, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement, Separate the LCD and digitizer: stap 39, afbeelding 2 van 2
    • Remove the six 1.2 mm Y000 screws from both sides of the display.
  40. iPhone SE 2020 LCD and Digitizer Replacement: stap 40, afbeelding 1 van 1
    • Heat an iOpener and lay it over the edge of the shield closest to the home button to soften the adhesive holding it in place.
  41. iPhone SE 2020 LCD and Digitizer Replacement: stap 41, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 41, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 41, afbeelding 3 van 3
    • Use an opening pick to break up the adhesive near the home button that holds the flat display cable to the LCD shield plate.
  42. iPhone SE 2020 LCD and Digitizer Replacement: stap 42, afbeelding 1 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 42, afbeelding 2 van 3 iPhone SE 2020 LCD and Digitizer Replacement: stap 42, afbeelding 3 van 3
    • Insert an opening pick from the bottom right corner and continue to separate the display cable from the LCD shield plate.
  43. iPhone SE 2020 LCD and Digitizer Replacement: stap 43, afbeelding 1 van 2 iPhone SE 2020 LCD and Digitizer Replacement: stap 43, afbeelding 2 van 2
    • Gently lift the LCD shield plate from the display assembly.
    • Be careful not to snag the display data cables when removing the LCD shield plate.
  44. iPhone SE 2020 LCD and Digitizer Replacement: stap 44, afbeelding 1 van 1
    • Only the LCD and digitizer remain.
Conclusie
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone SE 2020 Answers community for troubleshooting help.
39 andere personen hebben deze handleiding voltooid.
Adam O'Camb
217.580 Reputatie
416 handleidingen geschreven
4Gids Commentaar
Is anyone else experiencing low brightness after replacing the LCD? TrueTone to blame? Any known fix yet…
Device Trader - Antwoord
true tone is disabled after a screen swap. At least thats what I see online
catchpoler725 -
Will the screen replacement disable anything? I know it's common to have true tone disabled, but will replacing it disable touch id on this device?
Phone repair - Antwoord
Currently this device will still allow Touch ID to work after a screen repair, but if you try to replace the home button you will lose Touch ID functionality. It will work ONLY as a home button if you replace Touch ID.
BRUCEL86 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 96
Afgelopen 30 dagen: 454
Altijd: 54,280
