Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
iPhone 7 Plus Logic Board Replacement
Wat je nodig hebt
  1. iPhone 7 Plus Logic Board Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Logic Board Replacement, Opening Procedure: stap 2, afbeelding 1 van 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Plus Logic Board Replacement: stap 3, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 3, afbeelding 2 van 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Plus Logic Board Replacement: stap 4, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 4, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 4, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • While pulling up on the suction cup, twist the spudger to widen the opening between the screen and rear case.
  5. iPhone 7 Plus Logic Board Replacement: stap 5, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 5, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 5, afbeelding 3 van 3
    • Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
    • Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  6. iPhone 7 Plus Logic Board Replacement: stap 6, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 6, afbeelding 2 van 2
    • Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner.
    • Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
  7. iPhone 7 Plus Logic Board Replacement: stap 7, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 7, afbeelding 2 van 2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
  8. iPhone 7 Plus Logic Board Replacement: stap 8, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 8, afbeelding 2 van 2
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  9. iPhone 7 Plus Logic Board Replacement: stap 9, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 9, afbeelding 2 van 2
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  10. iPhone 7 Plus Logic Board Replacement: stap 10, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 10, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 10, afbeelding 3 van 3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  11. iPhone 7 Plus Logic Board Replacement, Battery Disconnection: stap 11, afbeelding 1 van 1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  12. iPhone 7 Plus Logic Board Replacement: stap 12, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 12, afbeelding 2 van 2
    • Remove the lower display cable bracket.
  13. iPhone 7 Plus Logic Board Replacement: stap 13, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 13, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 13, afbeelding 3 van 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  14. iPhone 7 Plus Logic Board Replacement, Display Assembly: stap 14, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement, Display Assembly: stap 14, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement, Display Assembly: stap 14, afbeelding 3 van 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  15. iPhone 7 Plus Logic Board Replacement: stap 15, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 15, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 15, afbeelding 3 van 3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  16. iPhone 7 Plus Logic Board Replacement: stap 16, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 16, afbeelding 2 van 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  17. iPhone 7 Plus Logic Board Replacement: stap 17, afbeelding 1 van 1
  18. iPhone 7 Plus Logic Board Replacement, Left Wi-Fi Antenna: stap 18, afbeelding 1 van 1
    • Remove three Phillips screws securing the antenna component:
    • Two 1.3 mm screws
    • One 1.2 mm screw
  19. iPhone 7 Plus Logic Board Replacement: stap 19, afbeelding 1 van 1
    • Remove the 1.3 mm Phillips screw securing the antenna component to the top edge of the rear case.
  20. iPhone 7 Plus Logic Board Replacement: stap 20, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 20, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 20, afbeelding 3 van 3
    • The screw boss at the top of the antenna component is tucked into a small recess in the top edge of the iPhone.
    • Tilt the antenna component up towards the top of the phone.
    • Slide the screw boss down and out of its recess.
  21. iPhone 7 Plus Logic Board Replacement: stap 21, afbeelding 1 van 1
    • Remove the top left antenna component.
  22. iPhone 7 Plus Logic Board Replacement, SIM Card: stap 22, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement, SIM Card: stap 22, afbeelding 2 van 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press firmly to eject the tray.
  23. iPhone 7 Plus Logic Board Replacement: stap 23, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 23, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 23, afbeelding 3 van 3
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket to protect your iPhone's internal components.
  24. iPhone 7 Plus Logic Board Replacement, Logic Board: stap 24, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement, Logic Board: stap 24, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement, Logic Board: stap 24, afbeelding 3 van 3
    • Use an iFixit opening tool or a fingernail to disconnect the dual camera cable connectors by prying them straight up from their sockets.
  25. iPhone 7 Plus Logic Board Replacement: stap 25, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Standoff Screwdriver for iPhones
    $5.49
    Koop
    • Remove the two screws securing the rear-facing camera bracket:
    • One 1.6 mm Phillips screw
    • One 2.2 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  26. iPhone 7 Plus Logic Board Replacement: stap 26, afbeelding 1 van 1
    • Remove the bracket covering the rear-facing camera.
  27. iPhone 7 Plus Logic Board Replacement: stap 27, afbeelding 1 van 1
    • Remove the two 1.3 mm Phillips screws securing the upper cable bracket.
  28. iPhone 7 Plus Logic Board Replacement: stap 28, afbeelding 1 van 1
    • Remove the upper cable bracket.
  29. iPhone 7 Plus Logic Board Replacement: stap 29, afbeelding 1 van 1
    • Remove the two 1.3 mm Phillips screws securing the grounding clip at the top left edge of the logic board.
  30. iPhone 7 Plus Logic Board Replacement: stap 30, afbeelding 1 van 1
    • Remove the grounding clip.
  31. iPhone 7 Plus Logic Board Replacement: stap 31, afbeelding 1 van 1
    • Remove the 1.3 mm Phillips screw securing the antenna flex cable to the top edge of the iPhone's rear case.
  32. iPhone 7 Plus Logic Board Replacement: stap 32, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 32, afbeelding 2 van 2
    • Use a fingernail or the sharp end of an iFixit opening tool to pry up and disconnect the antenna flex cable connector from the logic board.
  33. iPhone 7 Plus Logic Board Replacement: stap 33, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 33, afbeelding 2 van 2
    • Slide the flat edge of a spudger underneath the antenna flex cable to separate the adhesive holding it in place.
  34. iPhone 7 Plus Logic Board Replacement: stap 34, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 34, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 34, afbeelding 3 van 3
    • The screw boss at the top of the antenna flex cable is tucked into a small recess in the top edge of the iPhone.
    • Tilt the antenna flex cable up toward the top of the iPhone.
    • Remove the antenna flex cable.
  35. iPhone 7 Plus Logic Board Replacement: stap 35, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 35, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 35, afbeelding 3 van 3
    • Use a thin pry tool or tweezers to carefully pry up and disconnect the two coaxial cable connectors from the logic board.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat of your spudger. The connector should snap into place.
  36. iPhone 7 Plus Logic Board Replacement: stap 36, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 36, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 36, afbeelding 3 van 3
    • Disconnect the two remaining ribbon cables from the logic board:
    • Disconnect the upper cable connector by prying from the top
    • Disconnect the Lightning port connector by prying along the outer edge
  37. iPhone 7 Plus Logic Board Replacement: stap 37, afbeelding 1 van 1
    • Remove the seven screws securing the logic board:
    • One 1.3 mm Phillips screw
    • Two 2.1 mm standoff screws
    • Two 2.0 mm standoff screws
    • Two 2.2 mm standoff screws
    • Standoff screws are best removed using an [gekoppeld product ontbreekt of is uitgeschakeld: IF145-343] and driver handle.
  38. iPhone 7 Plus Logic Board Replacement: stap 38, afbeelding 1 van 2 iPhone 7 Plus Logic Board Replacement: stap 38, afbeelding 2 van 2
    • Use the point of a spudger to push the SIM card eject plunger out of the logic board's way.
  39. iPhone 7 Plus Logic Board Replacement: stap 39, afbeelding 1 van 1
    • Use the point of a spudger to carefully de-route the two coaxial cables from the small metal clip holding them to the logic board.
  40. iPhone 7 Plus Logic Board Replacement: stap 40, afbeelding 1 van 3 iPhone 7 Plus Logic Board Replacement: stap 40, afbeelding 2 van 3 iPhone 7 Plus Logic Board Replacement: stap 40, afbeelding 3 van 3
    • Lift the logic board from the bottom edges and slide it toward the bottom of the iPhone to remove it.
    • Be careful not to snag the logic board on any cables.
    • During reassembly, note the position of the black grounding clip at the top right edge of the logic board, near the rear cameras. The logic board should slide underneath the clip.
Conclusie
102 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
428.122 Reputatie
259 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
20 opmerkingen
Helo! Where can I buy motherboard for iPhone 7+ that can be activated? Price?
Dario - Antwoord
Can we use iphone 7+ 32gb board to a iphone 7+ 128 GB
Ali Mirsa -
You can purchase motherboard from this website.
https://www.aliexpress.com/w/wholesale-i...
Jose Palma -
It's really tough to install Board component but this guideline really helpful..
Flica Hussey - Antwoord
how can you determine the different stand of screws
joe kelly - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 132
Afgelopen 30 dagen: 626
Altijd: 161,902
