Ga door naar hoofdinhoud
iPhone 6s Front Panel Assembly Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. iPhone 6s Front Panel Assembly Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
  2. iPhone 6s Front Panel Assembly Replacement, Opening Procedure: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Clamp
    $24.95
    Koop
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. iPhone 6s Front Panel Assembly Replacement: stap 3, afbeelding 1 van 1
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 6s Front Panel Assembly Replacement: stap 4, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 4, afbeelding 2 van 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
  5. iPhone 6s Front Panel Assembly Replacement: stap 5, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 5, afbeelding 2 van 2
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
  6. iPhone 6s Front Panel Assembly Replacement: stap 6, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 6, afbeelding 2 van 2
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
  7. iPhone 6s Front Panel Assembly Replacement: stap 7, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 7, afbeelding 2 van 2
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
  8. iPhone 6s Front Panel Assembly Replacement: stap 8, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 8, afbeelding 2 van 2
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
  9. iPhone 6s Front Panel Assembly Replacement: stap 9, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 9, afbeelding 2 van 2
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
  10. iPhone 6s Front Panel Assembly Replacement: stap 10, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 10, afbeelding 2 van 2
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
  11. iPhone 6s Front Panel Assembly Replacement: stap 11, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 11, afbeelding 2 van 2
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
  12. iPhone 6s Front Panel Assembly Replacement: stap 12, afbeelding 1 van 3 iPhone 6s Front Panel Assembly Replacement: stap 12, afbeelding 2 van 3 iPhone 6s Front Panel Assembly Replacement: stap 12, afbeelding 3 van 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  13. iPhone 6s Front Panel Assembly Replacement, Battery Connector: stap 13, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    Koop
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  14. iPhone 6s Front Panel Assembly Replacement: stap 14, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 14, afbeelding 2 van 2
    • Remove the battery connector bracket from the iPhone.
  15. iPhone 6s Front Panel Assembly Replacement: stap 15, afbeelding 1 van 3 iPhone 6s Front Panel Assembly Replacement: stap 15, afbeelding 2 van 3 iPhone 6s Front Panel Assembly Replacement: stap 15, afbeelding 3 van 3
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  16. iPhone 6s Front Panel Assembly Replacement: stap 16, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 16, afbeelding 2 van 2
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
  17. iPhone 6s Front Panel Assembly Replacement, Unfasten the display cable bracket: stap 17, afbeelding 1 van 1
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
  18. iPhone 6s Front Panel Assembly Replacement: stap 18, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 18, afbeelding 2 van 2
    • Remove the display cable bracket.
  19. iPhone 6s Front Panel Assembly Replacement: stap 19, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 19, afbeelding 2 van 2
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
  20. iPhone 6s Front Panel Assembly Replacement: stap 20, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 20, afbeelding 2 van 2
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  21. iPhone 6s Front Panel Assembly Replacement: stap 21, afbeelding 1 van 2 iPhone 6s Front Panel Assembly Replacement: stap 21, afbeelding 2 van 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
  22. iPhone 6s Front Panel Assembly Replacement: stap 22, afbeelding 1 van 1
Conclusie
18 andere personen hebben deze handleiding voltooid.
Evan Noronha
223.487 Reputatie
168 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 8
Altijd: 4,300
