Ga door naar hoofdinhoud
iPhone 6 Front-Facing Camera and Sensor Cable Replacement
Wat je nodig hebt
  1. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Anti-Clamp instructions: stap 2, afbeelding 1 van 3 iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Anti-Clamp instructions: stap 2, afbeelding 2 van 3 iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Anti-Clamp instructions: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Clamp
    $24.95
    Koop
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 3, afbeelding 1 van 3 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 3, afbeelding 2 van 3 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 3, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Manual Opening Procedure: stap 4, afbeelding 1 van 1
    Anti-Clamp
    $24.95
    Koop
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 5, afbeelding 1 van 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 6, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 6, afbeelding 2 van 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Opening up the phone: stap 7, afbeelding 1 van 3 iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Opening up the phone: stap 7, afbeelding 2 van 3 iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Opening up the phone: stap 7, afbeelding 3 van 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 8, afbeelding 1 van 3 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 8, afbeelding 2 van 3 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 8, afbeelding 3 van 3
    • Open the display to about a 90Âş angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Removing the battery connector bracket screws: stap 9, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    Koop
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  10. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 10, afbeelding 1 van 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Disconnecting the battery connector: stap 11, afbeelding 1 van 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Removing the front panel assembly cable bracket screws: stap 12, afbeelding 1 van 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  13. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 13, afbeelding 1 van 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 14, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 14, afbeelding 2 van 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 15, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 15, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  16. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 16, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 16, afbeelding 2 van 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 17, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 17, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Separating front panel assembly and rear case: stap 18, afbeelding 1 van 1
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Earpiece Speaker: stap 19, afbeelding 1 van 1
    • Remove the following Phillips screws from the earpiece speaker/front-facing camera bracket:
    • One 2.3 mm screw
    • One 3.0 mm screw
    • One 2.2 mm screw
  20. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 20, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 20, afbeelding 2 van 2
    • Remove the earpiece speaker/front-facing camera bracket from the front panel.
  21. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 21, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 21, afbeelding 2 van 2
    • Lift the front-facing camera out of its recess in the front panel.
  22. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 22, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 22, afbeelding 2 van 2
    • Holding the front-facing camera out of the way, remove the earpiece speaker from the front panel.
    • Try not to touch any of the contacts on the speaker or the cable—skin oils can damage them and interrupt the connection. If you touch them by mistake, clean them with a little isopropyl alcohol and give them a few moments to air dry.
  23. iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Front-Facing Camera and Sensor Cable: stap 23, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement, Front-Facing Camera and Sensor Cable: stap 23, afbeelding 2 van 2
    • Keeping the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel.
  24. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 24, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 24, afbeelding 2 van 2
    • Fold the front-facing camera and sensor cable up to allow access to the microphone.
  25. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 25, afbeelding 1 van 2 iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 25, afbeelding 2 van 2
    • Carefully pry the microphone end of the sensor cable off of the adhesive holding it to the front panel.
  26. iPhone 6 Front-Facing Camera and Sensor Cable Replacement: stap 26, afbeelding 1 van 1
    • Remove the front-facing camera and sensor cable from the front panel.
Conclusie
410 andere personen hebben deze handleiding voltooid.
Sam Goldheart
465.970 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.299 handleidingen geschreven
50 opmerkingen
Perfect instructions, only confusion was where the sensor cable went. Would like a clear picture of sensor cable removed, as not to confuse viewer that the sensor cable is attached to the camera piece
Jamie Reigert - Antwoord
I accidentally ordered the cable for the 6S plus. Would it still function or are they pinned differently?
Dave Pratt - Antwoord
I did same mistake on a iphone 6 , i ordered the i6S front camera flex, it worked and im starting to believe it improved my camera ! On my iphone 6
It looks better than before!!
Jorge Fuentes -
We popped a 6s cable into an iPhone 6 to test. Everything fits and the camera does indeed work, although there is no improvement in resolution—the iPhone 6 doesn't seem able to use the extra pixels. We had mixed results with the other components on the cable assembly—the proximity sensor worked, but the ambient light sensor did not. We didn't test the microphone. Your mileage may vary, but I would recommend getting the correct part to avoid any unnecessary headaches. Cheers!
Jeff Suovanen -
Hey thinking to install iphone6s or iphone7 front camera on my old iphone6 is it possible or they are differently designed conponents
Which one will work ???? Plz help
Slmanpro -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 251
Altijd: 384,924
