Ga door naar hoofdinhoud
iPad Air 4 Rear Camera Replacement
Wat je nodig hebt
  1. iPad Air 4 Rear Camera Replacement, Prepare your iPad for disassembly: stap 1, afbeelding 1 van 1
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Air 4 Rear Camera Replacement, Heat the left edge: stap 2, afbeelding 1 van 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
  3. iPad Air 4 Rear Camera Replacement, Screen removal information: stap 3, afbeelding 1 van 2 iPad Air 4 Rear Camera Replacement, Screen removal information: stap 3, afbeelding 2 van 2
    • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
    • Camera module and ambient light sensors
    • Display cables
    • Screen magnets
    • Display edges
  4. iPad Air 4 Rear Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  5. iPad Air 4 Rear Camera Replacement: stap 5, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement: stap 5, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPad Air 4 Rear Camera Replacement: stap 6, afbeelding 1 van 2 iPad Air 4 Rear Camera Replacement: stap 6, afbeelding 2 van 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  7. iPad Air 4 Rear Camera Replacement, Insert an opening pick: stap 7, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Insert an opening pick: stap 7, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Insert an opening pick: stap 7, afbeelding 3 van 3
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Apply a suction handle to the top left edge of the screen.
    • Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
    • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
    • Insert the tip of an opening pick into the gap.
    • Don't insert the opening pick more than 3 mm or you'll damage the display edges.
    • Leave the pick in to prevent the adhesive from re-sealing.
  8. iPad Air 4 Rear Camera Replacement, Separate the left edge adhesive: stap 8, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Separate the left edge adhesive: stap 8, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Separate the left edge adhesive: stap 8, afbeelding 3 van 3
    • Don't insert the pick more than 3 mm or you'll damage the display edges.
    • Insert a new opening pick in the gap you just created.
    • Slide the opening pick along the left edge to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from re-sealing.
  9. iPad Air 4 Rear Camera Replacement, Heat the bottom edge: stap 9, afbeelding 1 van 1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  10. iPad Air 4 Rear Camera Replacement, Separate the bottom edge adhesive: stap 10, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Separate the bottom edge adhesive: stap 10, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Separate the bottom edge adhesive: stap 10, afbeelding 3 van 3
    • Don't insert the pick more than 3 mm or you'll damage the display cables.
    • Insert a new opening pick in the bottom left corner.
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the pick in the bottom right corner to prevent the adhesive from re-sealing.
  11. iPad Air 4 Rear Camera Replacement, Heat the right edge: stap 11, afbeelding 1 van 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  12. iPad Air 4 Rear Camera Replacement, Separate the right edge adhesive: stap 12, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Separate the right edge adhesive: stap 12, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Separate the right edge adhesive: stap 12, afbeelding 3 van 3
    • The right edge of the iPad contains the screen magnets, display cables, and a digitizer cable. These components are easily damaged if an opening pick is inserted too far.
    • Insert a new opening pick in the bottom right corner and slide along the right edge to separate the adhesive. Make sure to note the following marked areas:
    • Don't insert an opening pick more than 2 mm or you'll damage the screen magnets.
    • The screen magnets are located directly above the SIM card slot (Wi-Fi + Cellular models only) and volume buttons.
    • Don't insert an opening pick more than 3 mm or you'll damage the display and digitizer cables.
    • Don't insert an opening pick more than 5 mm or you'll damage the display edges.
    • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
  13. iPad Air 4 Rear Camera Replacement, Heat the top edge: stap 13, afbeelding 1 van 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  14. iPad Air 4 Rear Camera Replacement, Separate the top edge adhesive: stap 14, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Separate the top edge adhesive: stap 14, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Separate the top edge adhesive: stap 14, afbeelding 3 van 3
    • The top edge of the iPad contains the front camera module and two ambient light sensors. These components are easily damaged if an opening pick is inserted too far.
    • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
    • Insert a new opening pick in the top right corner and slide along the top edge to separate the adhesive. Make sure to note the following:
    • Don't insert an opening pick more than 3 mm or you'll damage the ambient light sensors.
    • Don't insert an opening pick more than 2 mm or you'll damage the front camera module.
    • Leave the pick in the top left corner to prevent the adhesive from re-sealing.
  15. iPad Air 4 Rear Camera Replacement, Reposition the screen: stap 15, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Reposition the screen: stap 15, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Reposition the screen: stap 15, afbeelding 3 van 3
    • Don't try to remove the screen yet, as it's still attached to the frame by delicate ribbon cables.
    • Grip the left edge of the screen and fold it open like a book.
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  16. iPad Air 4 Rear Camera Replacement, Disconnect the battery: stap 16, afbeelding 1 van 2 iPad Air 4 Rear Camera Replacement, Disconnect the battery: stap 16, afbeelding 2 van 2
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
  17. iPad Air 4 Rear Camera Replacement, Battery connector information: stap 17, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Battery connector information: stap 17, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Battery connector information: stap 17, afbeelding 3 van 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  18. iPad Air 4 Rear Camera Replacement, Create a battery blocker: stap 18, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Create a battery blocker: stap 18, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Create a battery blocker: stap 18, afbeelding 3 van 3
    • Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
    • The strips should be about 4 cm long so you can easily grip them.
  19. iPad Air 4 Rear Camera Replacement, Insert the card strips: stap 19, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Insert the card strips: stap 19, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Insert the card strips: stap 19, afbeelding 3 van 3
    • Insert the card strips on each side of the battery connector until they stop.
  20. iPad Air 4 Rear Camera Replacement, Unfasten the rear camera bracket: stap 20, afbeelding 1 van 2 iPad Air 4 Rear Camera Replacement, Unfasten the rear camera bracket: stap 20, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the rear camera cable bracket to the frame.
  21. iPad Air 4 Rear Camera Replacement, Remove the rear camera bracket: stap 21, afbeelding 1 van 2 iPad Air 4 Rear Camera Replacement, Remove the rear camera bracket: stap 21, afbeelding 2 van 2
    • Use tweezers or your fingers to remove the rear camera cable bracket.
  22. iPad Air 4 Rear Camera Replacement, Disconnect the rear camera cable: stap 22, afbeelding 1 van 2 iPad Air 4 Rear Camera Replacement, Disconnect the rear camera cable: stap 22, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the rear camera press connector.
  23. iPad Air 4 Rear Camera Replacement, Heat the rear camera: stap 23, afbeelding 1 van 1
    • The rear camera is secured to the frame with strong adhesive.
    • Lay the iPad screen side down.
    • Apply a heated iOpener to the rear camera for two minutes to weaken the adhesive.
  24. iPad Air 4 Rear Camera Replacement, Remove the rear camera: stap 24, afbeelding 1 van 3 iPad Air 4 Rear Camera Replacement, Remove the rear camera: stap 24, afbeelding 2 van 3 iPad Air 4 Rear Camera Replacement, Remove the rear camera: stap 24, afbeelding 3 van 3
    Tesa 61395 Tape
    $5.99
    • Lay the iPad screen side up.
    • Use the flat end of a spudger to pry up the rear camera.
    • If it's difficult to pry the camera up, apply a heated iOpener, wait two minutes, and try again.
    • Don't use isopropyl alcohol to weaken the adhesive or you'll damage the rear camera.
    • Remove the rear camera.
    • During reassembly, you can reuse the adhesive in the frame if it's still intact and clean.
    • If the adhesive is damaged or dirty, use tweezers to remove it and use a small piece of Tesa tape to secure the rear camera to the frame.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 4 answers community for help.
Chayton Ritter
22.528 Reputatie
105 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
9 Leden
11.426 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 44
Altijd: 1,102
