Inleiding
Use this guide to replace a broken or faulty FaceTime HD camera in your iMac Intel 21.5" EMC 2889.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Hold the display with one hand while using your other hand to unplug the display power cable.
Use the tip of a spudger to flip down the metal retaining bracket on the camera cable.
Remove the two 4.3 mm T5 Torx screws securing the camera board to the top of the rear enclosure.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
