iMac G5 17" Model A1058 Power Supply Replacement
Inleiding
Ga naar stap 1Keep those electrons flowing by replacing your broken power supply!
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Video overzicht
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
Gereedschap gebruikt in deze stap:Heavy-Duty Spudger$4.99
While depressing the connector lock, insert the flat end of a heavy duty spudger into the gap between the power supply connector and its socket.
Twist the heavy duty spudger to slightly separate the connector from its socket.
35 andere personen hebben deze handleiding voltooid.
