Inleiding
Replace your inverter board with this guide.
Wat je nodig hebt
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Slide the inverter-to-display cable connector from under the metal clip on the midplane.
Insert the flat end of a spudger between the plastic inverter cover and the inverter board.
Run the spudger along the edge of the inverter board to free all the tabs holding the plastic inverter cover to the inverter board.
3 andere personen hebben deze handleiding voltooid.
