Ga door naar hoofdinhoud
iHip Fold-up Portable Speaker Motherboard Replacement
Amanda
Amanda en 11 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
25 - 30 minuten
Moeilijk
This guide will walk you through how to replace the motherboard of the iHip Fold-Up Portable Speaker.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Place the device on a flat surface as shown.
    • Remove the battery case cover and batteries.
  2. iHip Fold-up Portable Speaker Motherboard Replacement: stap 2, afbeelding 1 van 3 iHip Fold-up Portable Speaker Motherboard Replacement: stap 2, afbeelding 2 van 3 iHip Fold-up Portable Speaker Motherboard Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using a Phillips-Head #1 screwdriver, unscrew the four outer 1.0 mm screws and remove with tweezers.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Remove the back cover carefully; there are many wires that connect it to the device.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  3. iHip Fold-up Portable Speaker Motherboard Replacement, Unscrewing the Motherboard: stap 3, afbeelding 1 van 2 iHip Fold-up Portable Speaker Motherboard Replacement, Unscrewing the Motherboard: stap 3, afbeelding 2 van 2
    • Observe the location of the motherboard at the bottom center of the back cover.
    • Using a Phillips-Head #1 screwdriver, carefully unscrew all three 0.4 mm screws from the indicated locations. Set aside for reassembly.
    • Using tweezers, gently remove the motherboard from the back cover of the device.
  4. iHip Fold-up Portable Speaker Motherboard Replacement, Cutting the Wires: stap 4, afbeelding 1 van 2 iHip Fold-up Portable Speaker Motherboard Replacement, Cutting the Wires: stap 4, afbeelding 2 van 2
    • Note the connection point of each wire to the motherboard.
    • Using utility scissors, cut all the wires connecting the motherboard to the device.
    • Using tweezers, place the new motherboard in the exact position of the old motherboard.
  5. iHip Fold-up Portable Speaker Motherboard Replacement, Soldering the Wires: stap 5, afbeelding 1 van 1
    • Read the manufacturer instructions for your specific soldering iron before use. Follow all safety instructions and solder at your own risk.
    • Position a strip of solder at the point of contact between the motherboard and each individual wire.
    • Solder the wires to the motherboard. Make sure to follow the manufacturer's instructions, as well as general soldering safety principles.
  6. iHip Fold-up Portable Speaker Motherboard Replacement, Securing the New Motherboard: stap 6, afbeelding 1 van 1
    • Using a Phillips-Head #1 screwdriver, screw the original 0.4 mm screws into the correct places to secure the motherboard back in place.
Conclusie
Amanda
201 Reputatie
2 handleidingen geschreven
Clemson, Team 3-4, Benson Fall 2014 Lid van Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 18
Altijd: 657
