Ga door naar hoofdinhoud
Repairing TRITTON Kunai Left Speaker
Engels
Nederlands
Stap 5
Repairing TRITTON Kunai Left Speaker: stap 0, afbeelding 1 van 1
  • This is the circuit board for the USB connection to the speakers.
  • Inspect the five solder points for a broken wire connection. They are labeled SP-, M-, M+, R-, and R.
  • If any connections are broken, re-solder the wires. Use this image as a reference for correct wiring.
  • Carefully test the headset. Avoid touching the internals while the device is plugged in.
  • If your speaker is now working, skip to the conclusion.
  • Reinforcing the wires with electrical tape before reassembly is recommended.
Vertaling hier toevoegen
