Ga door naar hoofdinhoud
Proctor Silex Model 24215 Toaster Lever Repair
Engels
Nederlands
Stap 5
Proctor Silex Model 24215 Toaster Lever Repair: stap 0, afbeelding 1 van 2 Proctor Silex Model 24215 Toaster Lever Repair: stap 0, afbeelding 2 van 2
  • Put the toaster right side up and gently lift up on the shell of the toaster.
  • Be careful when lifting the shell that you don't rip the connectors that are attached to the circuit board.
  • Disconnect the two connectors attached to the circuit board on each side of the toaster (4 total wires should be removed).
Vertaling hier toevoegen
