Ga door naar hoofdinhoud
Zeki Droid Tablet Battery Replacement
Wat je nodig hebt
    1. Zeki Droid Tablet Battery Replacement, Back Casing: stap 1, afbeelding 1 van 1
      • Remove the back casing by slowly popping each tab out with a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. Zeki Droid Tablet Battery Replacement: stap 2, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Remove the tapes one by one from the connecting wires with tweezers.
      Vraag FixBot
      Voeg opmerking toe
    3. Zeki Droid Tablet Battery Replacement: stap 3, afbeelding 1 van 1
      • Remove the black clips from both sides of the casing with a plastic opening tool.
      • The clips should pop off separate from the speakers.
      Vraag FixBot
      Voeg opmerking toe
    4. Zeki Droid Tablet Battery Replacement: stap 4, afbeelding 1 van 1
      • Remove the speakers from the back casing.
      • Do not tug on the speakers because they are connected to fragile wires.
      Vraag FixBot
      Voeg opmerking toe
    5. Zeki Droid Tablet Battery Replacement: stap 5, afbeelding 1 van 1
      • Pull the speakers away from the back casing carefullly.
      Vraag FixBot
      Voeg opmerking toe
    1. Zeki Droid Tablet Battery Replacement, Battery: stap 6, afbeelding 1 van 1
      • To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
      • Do not bend the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. Zeki Droid Tablet Battery Replacement: stap 7, afbeelding 1 van 1
      • To completely disconnect the battery, locate the two metal tabs connected to the small circuit board.
      • Using a soldering tool, you will desolder the tabs from the circuit board.
      • Please refer to the Hoe moet je (de-)solderen?
      • If your replacement battery already has the small circuit board attached, you can desolder the red and black wires connected to the mother board instead of the metal tabs.
      Vraag FixBot
      Voeg opmerking toe
    3. Zeki Droid Tablet Battery Replacement: stap 8, afbeelding 1 van 1
      • To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
      • Please refer to Hoe moet je (de-)solderen?
      • If you have the battery with the circuit board connected, then you can solder the red and black wires back to the mother board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kyla
156 Reputatie
2 handleidingen geschreven
Colorado Springs, Team 2-6, Panko Spring 2015 Lid van Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
3 Leden
10 handleidingen geschreven
3Gids Commentaar
will this be the same for a tbqc 1065b?
mark campbell - Antwoord Deel
how do i replace the screen mine has cracks?
This was my daughter's ...but the yeIIow pack the battery in is BLOWN TIGHT BULGING LIKE A BALLOON. DO I dare try to pry it off...not sure if it will exoIode. Yikes!!! She was murdered so I want to save it
CIaudia Bringe - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 6,062
