Ga door naar hoofdinhoud
VanMoof S3 Bell Button Replacement
Wat je nodig hebt
  1. VanMoof S3 Bell Button Replacement, Screwing around.: stap 1, afbeelding 1 van 3 VanMoof S3 Bell Button Replacement, Screwing around.: stap 1, afbeelding 2 van 3 VanMoof S3 Bell Button Replacement, Screwing around.: stap 1, afbeelding 3 van 3
    • In my case the button was glued additionally. Cut around it to make it loose.
    • Use the 2mm hex screwdriver and remove the tiny screw on the side of the bell housing.
    • Use the pliers to unscrew the button. Screw to the left.
    • You can't break what is already broken. It should come off easily, so keep cool. Although, in my case, the button top broke off.
    • Don't forget to turn off the bike!
    Wie schaltet man das Fahrrad aus wenn die Taste kaputt ist? Das Fahrrad schaltet sich bei mir die ganze Zeit an und aus, zwischendurch klingelt es. Ich kann nicht zwei Wochen warten bis die Werkstatt Zeit hat!!!
    Kjell Morgenstern - Antwoord
    Das geht am Rahmen der Unterseite von der Mittelstange. Da wo der Lautsprecher sitzt.
    Prokrastinator - Antwoord
  2. VanMoof S3 Bell Button Replacement, Hexen: stap 2, afbeelding 1 van 2 VanMoof S3 Bell Button Replacement, Hexen: stap 2, afbeelding 2 van 2
    • Loosen the 5mm screw located below the button.
    • If you unscrew both, you can try blowing compressed air through the holes. This may or may not solve the problem.
    • This screw holds the break/button part on the wheel. Later, you will need to pull it off. As you can see, the cable goes through the rubber grips.
  3. VanMoof S3 Bell Button Replacement, Handle this: stap 3, afbeelding 1 van 3 VanMoof S3 Bell Button Replacement, Handle this: stap 3, afbeelding 2 van 3 VanMoof S3 Bell Button Replacement, Handle this: stap 3, afbeelding 3 van 3
    • Use the wrench and the cloth to remove the handle grips. The cable goes through it - then through the handlebar.
    • At his point you could just solder a new button to the old cable and be done.
    • If you don't want to wait for replacement part from VanMoof - these buttons on Amazon have the exact dimensions and are waterproof,
    thank you very much for all the information.and the link where to buy.saves me a lot of time 🙏🏻
    Ronald Selter - Antwoord
  4. VanMoof S3 Bell Button Replacement, the goo: stap 4, afbeelding 1 van 3 VanMoof S3 Bell Button Replacement, the goo: stap 4, afbeelding 2 van 3 VanMoof S3 Bell Button Replacement, the goo: stap 4, afbeelding 3 van 3
    • Get rid of the old button. When you cut it off, the bike can turn on. So: Turn it off.
    • Clean the handlebar of the goo. In my case it was wet inside.
  5. VanMoof S3 Bell Button Replacement, the thread: stap 5, afbeelding 1 van 2 VanMoof S3 Bell Button Replacement, the thread: stap 5, afbeelding 2 van 2
    • Push the the whole break/bell part over the handle. And thread the new cable through the hole, as you can see in the picture.
    • Tie the old cable and the end of the new one together.
  6. VanMoof S3 Bell Button Replacement, red or black?: stap 6, afbeelding 1 van 3 VanMoof S3 Bell Button Replacement, red or black?: stap 6, afbeelding 2 van 3 VanMoof S3 Bell Button Replacement, red or black?: stap 6, afbeelding 3 van 3
    • Unscrew the handlebar with the 5mm hex wrench.
    • Remove the rubber cap located underside the handlebar. Remember where you put it.
    • In my case the bell button was the unmarked cable. Start to pull it to get the new one through. Good luck!
  7. VanMoof S3 Bell Button Replacement, second try: stap 7, afbeelding 1 van 3 VanMoof S3 Bell Button Replacement, second try: stap 7, afbeelding 2 van 3 VanMoof S3 Bell Button Replacement, second try: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • If you are unlucky and loose the cable inside. Try to fix it to a wire.
    • You can also try to use the wire, to block the path through that hole in the wheel, and push just the cable. It should than bend and appear in the hole.
    • Use the hole and the tweezers to get the cable halfway through.
    • Connect the cables. And try the bell.
  8. VanMoof S3 Bell Button Replacement, assembly: stap 8, afbeelding 1 van 3 VanMoof S3 Bell Button Replacement, assembly: stap 8, afbeelding 2 van 3 VanMoof S3 Bell Button Replacement, assembly: stap 8, afbeelding 3 van 3
    • Put everything back together. Use some proper electrical tape to get the cable in place.
    • Before you put the tiny 2mm hex screw should, check if hits the flat part of the side of the button.
    • I removed the old glue with the tweezers and applied some fresh hot glue.
  9. VanMoof S3 Bell Button Replacement, final report: stap 9, afbeelding 1 van 3 VanMoof S3 Bell Button Replacement, final report: stap 9, afbeelding 2 van 3 VanMoof S3 Bell Button Replacement, final report: stap 9, afbeelding 3 van 3
    • That was not so hard at all. It took me 40 minutes. But to for the future i come prepared. I designed this protection caps for the buttons. You can get them 3d printed on my ebay.
    • Link to Ebay NO if will not upload this to Thingiverse.
Conclusie
Prokrastinator
362 Reputatie
2 handleidingen geschreven
8Gids Commentaar
The link to the Ebay page seems broken
peter - Antwoord
Vielen Dank für diese ausführliche Anleitung. Das hat mir wirklich sehr geholfen beim E41!
joergjhansen - Antwoord
Moin hätte eine Frage welche Größe hat die Mini Schraube an der Seite vom Knopf hab sie verloren Weis jetzt nicht ob m2 oder 2.5 würde mich über eine Antwort freuen
IngoImTwingo - Antwoord
Hey my turbo boost is stuck in on position. Any advice on what to do?
Martin - Antwoord
Ich habe bei mir die booster-taste abgeklemmt weil mein X3 Tag und Nacht selbstständig die Gänge durchschaltet ich weiß mir nicht mehr zu helfen auch ein Reset bringt nichts !???? 😩
Günther Bartl - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 98
Afgelopen 30 dagen: 426
Altijd: 24,031
