Ga door naar hoofdinhoud
Upper Ice Maker Replacement
Wat je nodig hebt
    1. Upper Ice Maker Replacement, Unplug your refrigerator: stap 1, afbeelding 1 van 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser Fan Motor
      • Compressor Motor and Thermal Overload Device
      • Water Supply Valve Assembly
      Vraag FixBot
      Voeg opmerking toe
    1. Upper Ice Maker Replacement, Open the doors: stap 2, afbeelding 1 van 3 Upper Ice Maker Replacement, Open the doors: stap 2, afbeelding 2 van 3 Upper Ice Maker Replacement, Open the doors: stap 2, afbeelding 3 van 3
      • Open both refrigerator doors fully.
      Vraag FixBot
      Voeg opmerking toe
    1. Upper Ice Maker Replacement, Open the ice maker door: stap 3, afbeelding 1 van 3 Upper Ice Maker Replacement, Open the ice maker door: stap 3, afbeelding 2 van 3 Upper Ice Maker Replacement, Open the ice maker door: stap 3, afbeelding 3 van 3
      • Pull down the latch handle to release the ice maker door.
      • Swing open the ice maker door.
      Vraag FixBot
      Voeg opmerking toe
    2. Upper Ice Maker Replacement, Remove the ice bucket: stap 4, afbeelding 1 van 3 Upper Ice Maker Replacement, Remove the ice bucket: stap 4, afbeelding 2 van 3 Upper Ice Maker Replacement, Remove the ice bucket: stap 4, afbeelding 3 van 3
      • Using two hands, lift up the ice bucket slightly to release it.
      • Pull the bottom edge of the ice bucket toward you slightly and remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. Upper Ice Maker Replacement, Reassembly notes: stap 5, afbeelding 1 van 3 Upper Ice Maker Replacement, Reassembly notes: stap 5, afbeelding 2 van 3 Upper Ice Maker Replacement, Reassembly notes: stap 5, afbeelding 3 van 3
      • The drive hub notches and drive blade wings must line up before installing the ice bucket.
      • Rotate the ice bucket hub, located on the rear of the ice bucket, with your hand so that the notches will align with the auger motor drive blades.
      Vraag FixBot
      Voeg opmerking toe
    1. Upper Ice Maker Replacement, Remove the ice maker assembly screws: stap 6, afbeelding 1 van 2 Upper Ice Maker Replacement, Remove the ice maker assembly screws: stap 6, afbeelding 2 van 2
      • Use a #2 Philips driver to remove the three 15 mm‑long screws that secure the ice maker assembly to the refrigerator door.
      Vraag FixBot
      Voeg opmerking toe
    2. Upper Ice Maker Replacement, Reposition the ice maker assembly: stap 7, afbeelding 1 van 3 Upper Ice Maker Replacement, Reposition the ice maker assembly: stap 7, afbeelding 2 van 3 Upper Ice Maker Replacement, Reposition the ice maker assembly: stap 7, afbeelding 3 van 3
      • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
      • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
      Vraag FixBot
      Voeg opmerking toe
    3. Upper Ice Maker Replacement: stap 8, afbeelding 1 van 3 Upper Ice Maker Replacement: stap 8, afbeelding 2 van 3 Upper Ice Maker Replacement: stap 8, afbeelding 3 van 3
      • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
      • Squeeze the connector at the top of the ice maker assembly to release it.
      • Pull the connector straight down to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    4. Upper Ice Maker Replacement, Remove the ice maker assembly: stap 9, afbeelding 1 van 1
      • Remove the ice maker assembly.
      Vraag FixBot
      Voeg opmerking toe
    1. Upper Ice Maker Replacement, Remove the air duct from the ice maker: stap 10, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove the 14.4 mm‑long air duct screw from the side of the ice maker assembly.
      • The air duct gasket partially covers this screw.
      Vraag FixBot
      Voeg opmerking toe
    2. Upper Ice Maker Replacement: stap 11, afbeelding 1 van 2 Upper Ice Maker Replacement: stap 11, afbeelding 2 van 2
      • Remove the air duct.
      Vraag FixBot
      Voeg opmerking toe
    3. Upper Ice Maker Replacement, Remove the circuit board cover: stap 12, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove the two 32.5 mm‑long screws securing the circuit board cover.
      Vraag FixBot
      Voeg opmerking toe
    4. Upper Ice Maker Replacement: stap 13, afbeelding 1 van 2 Upper Ice Maker Replacement: stap 13, afbeelding 2 van 2
      • Open the circuit board cover.
      • The circuit board cover has wires that must be disconnected before removing the ice maker.
      Vraag FixBot
      Voeg opmerking toe
    5. Upper Ice Maker Replacement, Disconnect the ice maker wiring harness: stap 14, afbeelding 1 van 2 Upper Ice Maker Replacement, Disconnect the ice maker wiring harness: stap 14, afbeelding 2 van 2
      • Squeeze the three-wire connector to release it from the circuit board.
      • Pull the three-wire connector straight out to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    6. Upper Ice Maker Replacement: stap 15, afbeelding 1 van 3 Upper Ice Maker Replacement: stap 15, afbeelding 2 van 3 Upper Ice Maker Replacement: stap 15, afbeelding 3 van 3
      • Squeeze the multi-wire connector with the two orange wires running to the on/off switch.
      • Pull the connector straight out to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    7. Upper Ice Maker Replacement: stap 16, afbeelding 1 van 3 Upper Ice Maker Replacement: stap 16, afbeelding 2 van 3 Upper Ice Maker Replacement: stap 16, afbeelding 3 van 3
      • Use long nose pliers to pull the two spade connectors straight off the on-off switch terminals.
      Vraag FixBot
      Voeg opmerking toe
    8. Upper Ice Maker Replacement, Unfasten the ice maker from the back plate: stap 17, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove the three 16.5 mm‑long screws securing the ice maker to the back plate.
      Vraag FixBot
      Voeg opmerking toe
    9. Upper Ice Maker Replacement, Remove the ice maker from the back plate: stap 18, afbeelding 1 van 2 Upper Ice Maker Replacement, Remove the ice maker from the back plate: stap 18, afbeelding 2 van 2
      • Lift the ice maker off the back plate and remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
40.168 Reputatie
261 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
42.824 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 425
