Inleiding
This outline will show readers how to diagnose a faulty Water Heater element. It will also explain how to replace the complete Water Heater.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
At the breaker box, locate the breaker to the water heater and move the breaker bar to off.
Using a multimeter, check the line voltage at the water heater. You should have 0vac
Attach a garden hose (or any hose) to the drain valve that is located at the bottom of tank, near the lower access panel.
Open the drain valve on water heater. Once you have good water pressure coming out of the hose, slowly close the cold water valve to the water heater. If the water flowing out slows down, you can open the faucets at a sink or tub.
Tp install a new water heater, follow the installation instructions that came with the new water heater.
Één andere persoon heeft deze handleiding voltooid.
