Ga door naar hoofdinhoud
Tristar Handmixer Gears Replacement
njjong
njjong en een andere bijdrager
Voor het laatst geüpdatet op December 29, 2016
30 minuten
Eenvoudig
Be aware that too much liquid might harm the engine of the product. For opening the product a spanner screwdriver is needed.
Wat je nodig hebt
Gereedschap
  1. Tristar Handmixer Gears Replacement, Gears: stap 1, afbeelding 1 van 3 Tristar Handmixer Gears Replacement, Gears: stap 1, afbeelding 2 van 3 Tristar Handmixer Gears Replacement, Gears: stap 1, afbeelding 3 van 3
    • Remove all the screws with the spanner and Phillips screwdrivers.
  2. Tristar Handmixer Gears Replacement: stap 2, afbeelding 1 van 3 Tristar Handmixer Gears Replacement: stap 2, afbeelding 2 van 3 Tristar Handmixer Gears Replacement: stap 2, afbeelding 3 van 3
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
  3. Tristar Handmixer Gears Replacement: stap 3, afbeelding 1 van 3 Tristar Handmixer Gears Replacement: stap 3, afbeelding 2 van 3 Tristar Handmixer Gears Replacement: stap 3, afbeelding 3 van 3
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
  4. Tristar Handmixer Gears Replacement: stap 4, afbeelding 1 van 2 Tristar Handmixer Gears Replacement: stap 4, afbeelding 2 van 2
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
  5. Tristar Handmixer Gears Replacement: stap 5, afbeelding 1 van 1
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
    Excellent - gave you points for this guide.
    Question:
    The gears, where do we get them from?
    I'm refurbishing a vintage handmixer from the 60s, those here looks like they have same gear cut pattern but of course here we need exact replacements and no guessing.
    Anyone knows the most specialized and broad range mixer replacement part manufacturer?
    I will post also about this, but thought as I'm in the correct category here I could ask.
    My handmixer is on Deutsche Kunststoff Museum with search word "ABC MIX" it's a German vintage handmixer and only problem is the drive train wheel cog gears that should be nylon I think, not plastic not metal (sadly), so they deteriorate.
    Any help with great gratitude embraced!
    Henry - Antwoord
Conclusie
3 opmerkingen
where can I get replacement gears from?
lanz - Antwoord
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz -
On it now. Let's hope we don't need to buy Cheap-China-plastic. Ideal of course would be to find metal gears, that would last whole life (if not motor breaks).
I also need to find a manufacturer of cog drive train wheels, that could do custom made, tailored, because if you refurbish a vintage handmixer you need parts that are not manufactured or in circulation anymore.
Henry -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 1,757
