Toshiba Tecra Z50-A RAM Replacement
Inleiding
Ga naar stap 1RAM, or random access memory, is short-term storage for your Toshiba Tecra Z50-A. RAM is used by your processor for immediate use as needed, unlike long-term like files written to a hard disk drive. If your computer has slowed considerably or you’re looking for a boost, replacing/upgrading the RAM is a fairly simple and inexpensive first step. The Toshiba Tecra A50–A laptop comes standard with 8GB of RAM and can be upgraded to a maximum of 16GB with its two (DDR3) slots.
Wat je nodig hebt
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
