Ga door naar hoofdinhoud
Toshiba Satellite C50D-A Power Jack Replacement
Amber van Solingen
Amber van Solingen en 2 andere bijdragers
Voor het laatst geüpdatet op July 8, 2023
8 - 10 minuten
Gemiddeld
Ontbrekende stappen
In this guide, you will use a pry tool and a Phillips screwdriver to get to the power jack in order to replace or clean it. Should your power jack be defective or damaged, you can replace it with a new one.
Wat je nodig hebt
Gereedschap
  1. Toshiba Satellite C50D-A Power Jack Replacement, Battery: stap 1, afbeelding 1 van 1
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A Power Jack Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C50D-A Power Jack Replacement: stap 2, afbeelding 2 van 2
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A Power Jack Replacement, Lower Case: stap 3, afbeelding 1 van 2 Toshiba Satellite C50D-A Power Jack Replacement, Lower Case: stap 3, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A Power Jack Replacement: stap 4, afbeelding 1 van 1
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A Power Jack Replacement: stap 5, afbeelding 1 van 1
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A Power Jack Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite C50D-A Power Jack Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite C50D-A Power Jack Replacement: stap 6, afbeelding 3 van 3
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A Power Jack Replacement, Power Jack: stap 7, afbeelding 1 van 1
    • Locate the power jack at the back, right-hand side next to the USB port.
  8. Toshiba Satellite C50D-A Power Jack Replacement: stap 8, afbeelding 1 van 1
    • Carefully unhook it from the attachment sites.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 13
Altijd: 1,154
